Had the beetle at dealer for an oil change and they said the rear brakes are gone and quoted me $450 for the work. Never gone through brake pads that fast (60k) on a car before especially a manual I hardly use the brakes lol. Haven't got under there to look for myself can you even see the pads to measure how much is left? And the dealer said you can't just do pads have to do calipers and rotors the whole nine yards is this true? Was hoping to do pads myself and turn rotors if possible but VW confuse me
Thanks! |
Yes you can replace just the pads. The pads will cost you probably anywhere from $40 on the low end to whatever you want to spend. You need a tool to compress the calipers but it is not expensive, either.
DIY: Rear Brakes At 60K, I would put on nothing put pads. If it needs them at all.
'02 & '05 Acura RSX Dodge Cummins, Ford Ranger M151 Ford "Drive less, worry more. It's cheaper." Last edited by cep; 03-16-2010 at 02:31 AM.. |
rear brakes wear fast on these cars, and no you don't need caliper unless there is something wrong with them.
http://www.takepart.com/foodinc/ |
noR, you mentioned a tool available for $7 to compress/rotate the rear caliper. Where can I find that?
Thanks.
"No trees were killed in the sending of this message but a large number of electrons were terribly inconvenienced." Kenny's Silver '04 NB Convertible GLS 1.8 Turbo http://newbeetle.org/forums/photos-new-beetles/25692-kennys-silver-04-nb-convertible-gls-1-8-turbo.html |
OP - You should only need a new caliper if one binds or leaks fluid. Assuming both calipers are free to move then they can be replaced singly - unlike rotors and pads that should only be changed as an axle set on both wheels. |
I heard rumor there was a cube/tool from autozone that'd work, but i didn't have any luck w/that myself. And harbor freight may carry something, but I'm not sure about that either. I got my rear brake tool from parts4vws.com |
This is what I have now: Home Page > Search > Brake Tool > ES#9747 Brake Caliper Piston Tool - PBK-11PCS I bought the same set at Autozone around 8 years ago, under a different name, for quite a bit less and it works extremely well. edit: That price at ECS appears to be very good right now--Autozone is more! 60K is normal for rear brakes on a NB--both mine needed it around that time, my GTI got done around 75K, and my wife's Jetta has had new rears 2x and 1 front by mid-80ishK miles Last edited by wawalker; 03-16-2010 at 05:29 PM.. |
Probably not--I had 97K on my TS when I sold it with the original fronts still having life left.
| DIY: Rear Brakes | zeusenergy | 1.8 Liter Turbo | 13 | 08-31-2010 09:58 PM |
| Rear Brakes 2003 1.8T | digitalputty | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 01-22-2009 04:42 PM |
| Need Help with Rear Brakes Quickly | sarahbeetle | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 02-05-2007 04:09 AM |
| 25,000 miles and new rear brakes | finklejag | 2.0 Liter Gas | 6 | 06-18-2006 08:30 PM |
| Rear Brakes | Willard | 1.9 Liter TDI | 4 | 04-01-2006 01:20 PM |
