Turbine life span - NewBeetle.org Forums
Old 03-16-2010, 05:21 PM
Chaz1138's Avatar
New Beetle Lover
Johnsonville, NY, USA
Car: '00 GLS - Anette, '00 GLS - Beauty
Default Turbine life span
Hey guys. I tried searching for this info, but the forum search engine turned up 152 posts to comb through, so I decided to ask directly.
How long does the turbine last in these engines? Not the engine as a whole, but the just the turbine.
Also, a lot of these I find for sale are around 90k OR 120k- 140k. I know the water pups can go around 90K, but what else can happen around the 120k - 140k mileage range?
Thanks!
Old 03-16-2010, 08:56 PM
Chaz1138's Avatar
New Beetle Lover
By that, are you talking about damage or the installation of a chip to add hp?
Originally Posted by wawalker View Post
IWas it put under the added stress of being chipped?
Old 03-17-2010, 12:48 PM
noR's Avatar
Administrator
Jackson, MS, USA
generally you can expect 100K+ from the stock turbo.
Chipped or not.
Manual boost controllers are a different story all together.
noR | me | Phrog
PHROG
Old 03-28-2010, 03:16 AM
I am looking at an 87K bug with a turbo, what could you expect to happen when the turn craps out? I mean can the car run without it?
Old 03-28-2010, 10:08 PM
eliteboi's Avatar
Denver, CO, CO, USA
Car: 1995 Saab 9000 CSE- 200 HP and counting!
If you can't afford to fix it if it breaks, don't buy it.
Hardey's MoToRwErKs- The only place to trust your VW/Audi to in Metro Denver
Old 03-31-2010, 08:39 AM
Did anyone say anything about affording? Why be a prick? I know for me, affording isn't an issue, it's a matter of dealing with it if it goes out. So don't be a prick and maybe think a bit before you say something.
Old 03-31-2010, 12:02 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
The wife's '00T is original and I have not had a problem with it (knocks on wood) and she has 150k+ on hers.
My NB Family...
Old 03-31-2010, 12:06 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Yes but badly. The engine runs off-boost a lot of the time anyway but you will know the difference. Some failures are the oid seals in which case you'll leave a smog trail and likely get pulled for emissions anyway (depending on where you live).
If the car runs good when you get it then prepare for water pump/timing belt and other routine maintenance, turbo failure isn't so predictable as it depends on oil, frequency of oil changes, usage and whether it has been shut off hot many times...
Cheers
Simon
Old 03-31-2010, 08:24 PM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
I know your new here. So let me give you a word of advice. Take whatever is said with a grain of salt. Is it really worth getting worked up over a simple statement. Don't go calling people derogatory names. You will find a lot of useful information her, as well as some BS. If you think it's BS, then it probably is. Just ignore it, and let it go. Like you said, think before you say something,.....is it really worth it?
Old 03-31-2010, 10:14 PM
noR's Avatar
Administrator
Jackson, MS, USA
Site Rules - NewBeetle.org And I'll just direct your attention to Rule #9 here.
Seemed like he left you good advice to me. I can't tell you how many people I see complaining about financial problems here.
Anyway, it'll run, it'll run poorly. You'd probably be leaking oil like crazy, maybe even trying to push oil through the intake manifold. But who knows. There's umpteen different ways a turbo could die, from seals becomming non-existant, to a shaft bending and the turbine locking up.
Or maybe pieces of vanes breaking off sending shrapnal to the intercooler.
How about a more specific question... Maybe a new thread asking if anyone has actually had their turbo fail on them. Then you can ask them for first-hand information, maybe we'll get a correlation going.
Old 04-01-2010, 09:09 PM
eliteboi's Avatar
Denver, CO, CO, USA
I wasn't trying to be a prick, honestly. I just dislike when people buy these cars then complain, or can't fix them because of money.
Tags
life span , mileage , turbo
engine life span dwtruland 2.0 Liter Gas 4 05-13-2008 09:47 PM
VW Bug 4 life! rcarr67 New Member Forum 6 02-13-2007 06:01 PM
A Day In The Life scarabY2k The New Beetle Experience 1 02-11-2006 09:52 PM
A Day In The Life scarabY2k Photos: New Beetles 4 02-11-2006 07:59 PM
Still some life in the old dog CGK Miscellaneous Hoo-Ha Archive 2 11-30-2005 06:33 PM
