I'll give it a shot.
Based on the fact that the noise goes away upon acceleration, have you checked the oil level? If the oil pressure is low, which could be caused by a lack of oil, if might be the lifters. I am not certain about the Beetle but my old Jetta had hydralic lifters to work the valves and it could clatter upon start up until the oil pressure was sufficient. |
From the back center of the motor? An alternator? Naw, the alternator is attached to the front of the block.
Try this. Get some plastic pipe. About two feet long. With the motor running, put one end of the pipe to your ear, then move it around until the sound is the loudest. The pipe will be pointing at the problem. Just from the description, a wild guess would be an exhaust leak. See if the sound is from around the turbo.
I have been accused of many things, sane is not one of them. |
A clicking sound will not be exhaust. if it was exhaust it would get louder under acceleration.A clicking sound could be your valve train. b/c if your oil is low when you accelerate your oil pressure rises and would take care of the lifters getting lubed up. I would check your oil level. It sounds like a lifter. |
My 2002 Turbo does this same thing. It is only audible at idle and sometimes not even then. I have a horrible VW dealership in my area so haven't even brought it in to have it looked at, they would just give me the run around anyway.
Jaimie |
i just fixed this problem on my wifes 01 sport.
what you have is a bad timing belt idler. the clicking is the belt getting loose and slapping inside the cover. the part is about 80 bucks from vw. replace it, and no more diesel sounds. hope this helps |
| Clicking noise from front | midnightluna | Questions, Issues, Concerns, or Problems with the New Beetle | 6 | 01-27-2008 04:43 AM |
| Clicking with iPod interface | nosebite | Car Audio | 3 | 12-27-2005 09:39 PM |
| 2002 Beetle clicking noise rear left... help? | DonaldLL | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 12-12-2005 05:22 PM |
| Loud Rattling Noise | Keimax4h | 2.0 Liter Gas | 8 | 11-25-2005 06:48 PM |
| sound system | tarheel1 | New Member Forum | 0 | 11-07-2005 09:56 PM |
