Please Help!! AC not working - NewBeetle.org Forums
Old 03-24-2010, 06:52 PM
Lady Bug!'s Avatar
Unhappy Please Help!! AC not working
ahhh... well Im new here and just love my 2000 VW Beetle 1.8 Turbo... So Cute!
Well My air is not working. I had it checked out at a repair shop, and they can not figure it out...
all is good... freeon-compressor-fuses-hi pressure switch.
it just blows warm air, not hot like the heater just warm..
Any suggestion???
thank you in advance!!
Old 03-24-2010, 07:21 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Sounds like the air blend flap is stuck and/or the mechanism is broken. The NB heater matrix is always hot, the temp is controlled by a blend flap mixing warm and cold air, if it is stuck partially warm then you get permanent warm air. Can you make it hotter but not cold or is it a constant temp once the engine is warm???
If it is that then search as I think there is a good how-to thread with a guide on fixing the flap and mech. Quite a bit of stripping the dash is involved from memory so if you can do it your self there are $$$ to be saved...
Cheers
Simon
Old 03-24-2010, 09:26 PM
Lady Bug!'s Avatar
oooo... thank you... I will check if it gets hotter, i kinda think it does.. its way hotter with the heater on... is that what you mean? thank you!
Old 03-25-2010, 04:30 PM
Glendale, AZ,
It sounds like you are having the same problem i had. It ended up being the 30amp fuse on top of the battery. There are 6 wire fuses and 3 30amp blade fuses. It is the first blade fuse to the left that was the problem for me, so i swapped it for the fuse furthest to the right and then stated the car, turned on the air and voila the A/c worked. so i went and bought 3 new 30amp fuses for a couple bucks and replaced all 3. Try it, hope it works for you.
Old 03-26-2010, 03:49 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
It could be as mjasim pointed out or the Blend Door. Check out the fuse block on top of the battery to see if any fuses appear to be melted; if none are melted, read the Blend Door DIY to see if it matches your problem.
My NB Family...
Old 03-30-2010, 01:57 AM
Lady Bug!'s Avatar
ok we checked the fuses all good! i guess the compressor is not kicking on.. it spins freely but wont kick on! is there a low pressure switch somewhere?
sorry for the ignorance. I do not have a owners manual.. I need to invest in one.
thanks
Old 03-30-2010, 12:09 PM
D2Beetle's Avatar
NB Yellow Trifecta
You should consider checking the following...
1) The A/C fan control module
2) The A/C Temp sensors
I have a question, in your first post you said... "I had it checked out at a repair shop, and they can not figure it out...
all is good... freeon-compressor-fuses-hi pressure switch."
Did the compressor actually come on when they checked it?
Old 03-30-2010, 09:05 PM
Lady Bug!'s Avatar
The compressor does not come on...
I apologize I was confused. They spun the compressor with their hands, to know it is not frozen up.
Old 03-30-2010, 11:19 PM
D2Beetle's Avatar
NB Yellow Trifecta
I find that interesting; turning the A/C clutch with your hands means little, because it is designed to turn freely while not turned on. So we know the clutch can rotate freely.
If you really want to replace the clutch, read this post.
To check for a frozen compressor you must engage the clutch. There is an easy way to test the clutch; unplug the two wire (green-brown) connector. The photo shows the wire, but some schmuck who will rename nameless cut the connector off. Put a jumper wire from the positive side of the battery to the compressors connector. If the clutch is good you will hear the clack when it engages.
This is what I'm working with sublow1 Photos: New Beetles 27 12-03-2009 06:16 PM
AC Not Working DadOfATurboSOwner 1.8 Liter Turbo 6 07-28-2009 12:06 PM
A/C Quite working Devil Yellow 1.8 Liter Turbo 1 08-07-2007 12:31 AM
a/c not working lukeca Questions, Issues, Concerns, or Problems with the New Beetle 1 07-18-2006 01:42 AM
A/C not working - help! tjthorson Questions, Issues, Concerns, or Problems with the New Beetle 7 07-07-2006 01:21 AM
