Help! Car won't go into gear!!!!! - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 04-05-2010, 12:14 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Originally Posted by ched454 View Post
The hydraulic slave cylinder doesn't care whether the car is running or not running.
True, but... excerpt from this website
"...The clutch pedal is connected to the disengagement mechanism either by a cable or, more commonly, by a hydraulic system. Either way, pushing the pedal down operates the disengagement mechanism which puts pressure on the fingers of the clutch diaphragm via a throwout bearing and causes the diaphragm to release the clutch plate. With a hydraulic mechanism, the clutch pedal arm operates a piston in the clutch master cylinder. This forces hydraulic fluid through a pipe to the clutch slave cylinder where a another piston operates the clutch disengagement mechanism. ..."
The slave cylinder is used to engage/disengage the clutch; if there is insufficient hydraulic pressure the slave cylinder would be unable to perform its function properly. There is more stress (pressure) on a clutch when the motor is running vice when it is not.
I say check the slave cylinder, it is a win, win. If it is the slave cylinder, you just fixed it, if not, then you know it is something mechanical; throwout bearing would be my guess.
My NB Family...
  #22 (permalink)
Old 05-01-2010, 12:37 AM
Blitz Kafer's Avatar
"Lightning Beetle"
Winter Park, FL, USA
Car: 2000 Beetle 1.8t Blue
Exclamation
Sorry, its been a while I was going to sell the car but, I decided not to so I started to tear into it to check the clutch and when I pulled the slave cylinder the green boot was ripped and it was leaking fluid. I'm going to replace it but is this the problem?
2001 1.8t,5spd,K03s,APR 91octane tune,4bar fpr,diode mod,fmic,forge dv & tip,n75r,cai,kinetic hf mani,3in downpipe,2.5in exhaust,no cat,VR6 clutch,guages,clubsport springs & shocks,shortshifter,HID's.
  #23 (permalink)
Old 05-01-2010, 07:11 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
The problem doesn't sound hydraulic to me or else he would have trouble getting it into gear when the car is running or not. It sounds mechanical under a load and is probably the pressure plate especially if it is the underrated OEM original part.
NoR is right, no hydraulics won't affect going into gear without the engine running. Try it in yours, stop the engine, don't touch the clutch, you'll find she will go into gear just fine...
Cheers
Simon
What gear for Dyno Trbowgn 1.8 Liter Turbo 22 01-02-2008 02:09 PM
gear problem cocorunwild 2.0 Liter Gas 0 12-09-2007 06:02 PM
Top Gear Mazzzja Miscellaneous Hoo-Ha Archive 12 07-07-2006 02:22 AM
Gear Shift Ivy Styling Modifications 6 04-27-2006 05:40 PM
new car will not go in gear (auto trans. ) mikesbug New Member Forum 3 03-12-2006 03:06 PM
