I don't know if this is a symptom with a manual transmission, but automatics have similar issues because of the brake switch.
Do you have a Check Engine Light? Is your EPC light on? I was having a little minor difficulty with shifting into first and my EPC light was staying on until I had the brake light switch changed. Mine was covered under the VW recall...I don't know about 01',but you might want to check that as well. |
I checked but there are no codes, no epc. I don't know if it matters but it goes into gear fine when the cars not running. This sucks! I'm trying to buy a house right now and I don't have the money for this! This is my only car to drive at the moment so I need to fix it.
Also have you check your brake fluid lately? The clutch uses the same fluid.
My NB Family... |
I just had my shift linkage break and its a very different symptom. Your shifter goes limp. But had 3rd and 4th. No issues with the clutch.
Yes checked and filled the brake fluid but it made no difference. I checked the linkage and it seems to be ok if the motor is off it goes into all the gears fine but as soon as i start the car it won't go into gear.
Going into gear with motor not running really does not say much, as the motor and tranny are not under any stress. I did the same thing when the shift carrier broke on mine, the linkage moved, but I really could not tell if that movement was right or wrong. |
I drove through a big puddle before it did this and my vw mech friend told me that the clutch probably got wet and rusted together. I tried slamming it into gear to break it loose but it didn't work. with the car off i put it in first with the clutch in and turn the key to start it. I barely turn the key and the car jumps forward jerking violently until it starts going then if i slam it into each gear i can get all the gears (shifting up from one to the next) but if i take it out of gear it won't go back in and i can't downshift into any gear. if i slow down to about 5mph i can slam it back into first but it starts to buck again until i speed up. also once i get it into a gear i have to pull hard to get it out. with the car stopped and running i tried to slam it into reverse but the car died.
I think my clutch is locked up. Any suggestions? ![]() Thanks |
And you might want to stop the mechanical diagnostic procedures or you will need a new tranny. Exactly how deep was that "puddle"? ![]() |
You may just need a slave cylinder. It's the thing that pushes on the clutch fork. It sounds like when you press on the pedal, your clutch fork isn't moving.
I don't know what people think your clutch is bad. When a clutch fails, it WON'T engage. Your problem is that you can't get the pressure plate to DISengage. Two very different problems. The fact that it's locked in is a sure sign your clutch is a-okay in itself. Heh, unless it's welded itself to the pressure-plate. :P Yoiu haven't been having alot of clutch slip lately have you? |
I'm not really sure how to diagnose the slave cyl. You can remove it from the transmission, but I don't know how you're supposed to check to see if it's providing "spec" pressure.
You see that diamond shape mounting position near the top, it has 2 bolt holes and one round openning in the middle? That openning and those 2 bolt holes, that's your slave cylinder.Another possible cause could be a broken shift-fork. I had mine break once. But it would bend instead of pressing. So it SORTA engaged, and it was accompanies by the teeth of the pressure plate banging against the fork. It was pretty gnarly. So what' the pedal feedback like? Do is press in and resist like normal? Does it push back out on its own, or do you have to pry it off the floorboard? Last edited by noR; 03-30-2010 at 02:00 PM.. |
I'll look up the slave cylinder on the Bentley DVD and see what it shows/says. |
Thanks, I'm running low on ideas really.
No fluid loss what-so-ever; then I think you need to pull the transmission and look at your clutch parts. Something is keeping you foot from actuating the slave cylinder or the slave cylinder from pushing the clutch fork, or the clutch fork from pushing the throwout bearing into the pressure plate fingers, or the fingers from leveraging the pressure plate away from the flywheel. It's gotta be right in there somewhere. :/ |
The problem doesn't sound hydraulic to me or else he would have trouble getting it into gear when the car is running or not. It sounds mechanical under a load and is probably the pressure plate especially if it is the underrated OEM original part.
| What gear for Dyno | Trbowgn | 1.8 Liter Turbo | 22 | 01-02-2008 02:09 PM |
| gear problem | cocorunwild | 2.0 Liter Gas | 0 | 12-09-2007 06:02 PM |
| Top Gear | Mazzzja | Miscellaneous Hoo-Ha Archive | 12 | 07-07-2006 02:22 AM |
| Gear Shift | Ivy | Styling Modifications | 6 | 04-27-2006 05:40 PM |
| new car will not go in gear (auto trans. ) | mikesbug | New Member Forum | 3 | 03-12-2006 03:06 PM |
