Blue Temp Light and Red Oil Light - NewBeetle.org Forums
Old 04-02-2010, 02:17 AM
Default Blue Temp Light and Red Oil Light
Well, looks like we have an issue starting already. The Blue coolant light seems to like coming on as it pleases. Im guessing that is due to the faulty sensor, so that should be taken care of here in the next week.
We are also getting a flashing oil light. It will only do it once or twice in a day. The car will be driving perfect and as you come up to a stop the oil light will flash and beep three times. It only does this when the rpms are low, so If put in nuetral and reved a little, the light will go off, btu come back on after the rpms drop for a bit. I read that this could be linked to the coolant sensor malfunction?? What else should I be conserned with checking???
Old 04-02-2010, 02:20 AM
oceanjoe89's Avatar
Perry, IA, USA
Definitely check out your coolant temp sensor, and, if it isn't a green on, change it out!
as for the oil light... you've checked your oil, right? you have plenty?
also, what engine do you have. if you have the 1.8T, you need to be running synthetic, Flbug will attest to this. Regular oil will turn to sludge and gum up the passageways and cause a similar symptom to what you are experiencing.
good luck! keep us posted!
Junior (My Car)
Jake (Me)
Old 04-02-2010, 05:02 AM
Karaokerobot's Avatar
Kennesaw, GA, USA
Car: 03 Black Beetle
Hi there! I hope I might help...
When I had first bought my 2003 last year my blue temp. light kept on coming on too!
I would have to stop half a mile down the road because it would then start beeping at me! I couldn't figure out what was wrong.
A few weeks later, I got my bugs first oil change and the beeping went away!!!! It still comes on when I start my car but by the time im out of my driveway it's off.
Maybe that's all it takes?
Who knows.
Old 04-02-2010, 07:36 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Yellow or red flashing oil light???
Yellow means level low, red means pressure low.
Cheers
Simon
Old 04-02-2010, 01:15 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Blue light coming back on means you need a Coolant Temp sensor. You can buy them at Advance Autoparts for $9.99 WITH the Oring on them. Easy to change. Its MUCH easier if you take the airbox out when you do it. I'd also recommend you visit a Vw Dealership and order a retaining clip for it too. Its $.56. I BET you will somehow manage to lose yours. I was REALLY careful but it fell somewhere into the dark spaces in the engine bay. I was not about to dig around in there for a $.56 piece of plastic.
Red Oil light means pressure issues. What you should do ASAP is get an oil change. BUT, after the oil is drained, you will need to take the oil pan off and clean the filter screens in there. It MOST likely will be all kinds of gunked up because somewhere along the line synthetic oil was not used. Afterwards, replace with SYNTHETIC OIL that meets the Vw 505.1 requirements. You can probablly get this done in one sitting, but if its bad like was, you may need to do it multiple times. I didn't know this and i went through 3 oil changes in the month of November of 2009.
If you do not clean the screens and you just change the oil, the light will be back on in almost EXACTLY 1,000 miles and you will need to do what is mentioned in the previous paragraph.
Finally, Advance Autoparts is having a killer sale on oil and filters lately, you may want to go grab a few quarts and filters. Here is a link to their Oil Specials. Again, make sure you get synthetic.
Old 04-02-2010, 04:17 PM
Rbug's Avatar
Riverside, CA, USA
Car: 05 New Beetle GL
If you search for the problem you describe, blue coolant light and oil pressure light and beep, you will find that the coolant temp sensor can cause feedback to the oil light. Many have reported that changing out the coolant sensor fixed the oil light problem, too. Electonics! go figure.
Rich
Oil Light - Cold Temp Light Flash iamregin 1.8 Liter Turbo 3 06-30-2009 01:54 AM
Blue Temp Light TTownBug Questions, Issues, Concerns, or Problems with the New Beetle 4 06-09-2009 09:24 PM
Oil Light/Temp Light Alisha 1.8 Liter Turbo 6 04-14-2009 07:16 PM
blue light(low temp. light) and (red light) oil lights devioushaze 1.8 Liter Turbo 1 06-09-2007 12:24 AM
red temp light-please help Heather99 Questions, Issues, Concerns, or Problems with the New Beetle 4 05-05-2006 12:35 PM
