Is the downpipe neck broken a common problem ? - NewBeetle.org Forums
Old 04-03-2010, 12:19 AM
Default Is the downpipe neck broken a common problem ?
Hi. On my 2000 VW Beetle 1.8T APH, I'm in the middle of replacing the stock downpipe/CAT cause the metal neck of the downpipe is broken. The part near the turbo, between the turbo and the flexible part of the pipe. The part alone is $600.00 and it's upsetting cause the CAT itself is fine, but that's what you pay for. Now I heard this exact thing happened to a friend of mine with a similar year Audi A4 1.8T. That mechanic said the dogbone mount was shot, caused too much engine play/stress on the downpipe. So I look at my stock dogbone mount ('replaced about 20000 miles ago) and sure enough the small cylidrical bushing doesn't look so great. I guess I'll replace that too.
Old 04-05-2010, 11:05 PM
Beetlecup's Avatar
senior member
Tampa / St. Petersburg, FL, USA
Car: 2003 Turbo S
There is after market down pipes that are cheaper with cats. Might give you a few extra hp also.
water neck flange- what is it? dolce 2.0 Liter Gas 7 06-09-2009 01:06 AM
Show your Red Neck Items Boopster Miscellaneous Hoo-Ha 11 10-10-2008 04:38 AM
anyone have neck/back surgery?????? bugsy98nb Miscellaneous Hoo-Ha Archive 22 05-17-2007 01:12 AM
Need help on common problem! Midas Wellby Questions, Issues, Concerns, or Problems with the New Beetle 14 01-28-2007 05:54 PM
