Thats what sucks, is trying to design something for people who dont want to relocate half the car. If I was doing this for myself only, I could have had it done in 1/5th the time and greif.
But yeah, coming from the IC back to the TB, it comes striahgt out, then bends up a bit to get tight to the end of the frame rail, then bends up a bit more(one bend wouldnt work because the bend ended up hitting the turnsignal), then finally bends back under the headlight. You know the rest. There is like 2.5", maybe 3" of space from side to side between the frame rail and the pocket in the bumper cover for the turn signal. I managed to get the piping to fit up in that little groove. If I showed a pic, it would seem like the end result was obvious. Not quite so obvious Im sure you know when you are sitting there with a pile of bends, welder, a grinder(to cut the welds back off), etc putting the bumper on and off on and off etc...I never would have thought I would have to do so many little doglegs. You had roughly 500 degrees in bends, but only 6 total bends. Mine has 400 degrees in bends, but 7 bends. So yeah, I got less degrees and more bends. So your original statement was sorta accurate Its alot of 45s. |
Great info-really enjoying this thread-I also have auto trans and i do want a fmic.
The question I have on fmic is water temp. Will nb run a little hotter. I am asking this because I have read about some having temp problem with fmic installed. But this could be because of improper installation. |
Yeah this is a great thread!
Sort of listening in as you figure out how to do this. I'd be very interested in the final product. I am one that doesn't want to relocate much if anything, but would love a fairly direct piped FMIC install which fits under the stock front. Keep it up and keep us posted!!
SOLD!: 2001 Batik Blue GLX 1.8T, 5sp, Revo Stage2, Eurosport TB exhaust, Neuspeed Sofsports + F&R sways, KYB AGX, 13"/10" F/R vented brakes, Stock Daytonas wrapped with 225/45/17 Proxes4. |
![]() The IC should fit with NO body mods whatsoever I'm guessing. When I mocked up my TS bumper on my TDI, I found that I could shove a ABD core in no prob. ![]()
Cool thread. I've been looking for a good OEM IC replacement set-up and the Tyrolsport was the one I liked the best due to OEM fittment. Basically just bolt and go (very minimal cutting with no parts needing to be moved).
As NJ Turbo mentioned, they don't make it NB friendly though... ![]() Hey, if you build it, they will come, with cash!!! TechnoTrix'd.. |
The water temp thing is a good question and something I look forward to finding out.
Im confident that it wont end up being much of a problem though. The intercooler core has a gap between the core and the AC condensor, meaning that air can move around behind the core. Also, as mentioned this IS going to require trimming or removal of the bumper bar. If you trim the bare minumum out of the bumper bar, you will obviously cut off airflow to a significant part of the cooler and the radiator. If you leave the bumper bar off, I doubt there will be any kind of issue. I've been hesitant to give out much info lately while the details get worked out. Like I said, if I was doing these one off in a shop it would be easy, but all this stuff needs to be jig done so that they are all exactly the same, which means building the jigs and so forth. That and other things like getting boxes to get everything in as well as redesigning the website to go with it is takin time. Considering the size of the cooler, mods to the car though are pretty minimal. The battery stays in the stock location(although it if you trunk mount it, you will get loads of room to do a true cold air intake). The stock air box gets trashed, but the kit will include a K&N cone filter for the air meter and for the air pump, as mentioned the bumper gets modifed or left out, as seen in the pics the radiator trim needs to be trimmed, the grillework needs to be trimmed a bit, and the fog lights will need to be modified if you want to keep them. Yeah, its not a 100% throw it on and go, but on the other hand its still alot easier than what alot of other cars need to be done. The exhausts are going to be available sooner. I should be inthe last few stages of prototyping now, and then its just a matter of getting the time to produce the production systems. The price on the exhausts is definately well within if not under the predicted price. So if you are itchin to get this kind of stuff, hit me up and I will let you know where things stand. |
Any word on the exhaust?
http://www.myspace.com/4603066 |
2001 New Beetle TDI 5sp- RC 2/3 ASV, PP520s, G60/VR6 Clutch, Boostvalve, EGR-ectomy, Panzer Skid Plate, Ventectomy. 184,000 miles (October '06) 43mpg 70% city driving |
| Interest Guage: NB.org Dashboard Widget for OS X? | jcroft | Suggestion Box | 18 | 04-03-2006 11:26 PM |
| Gauging Interest - Watches with YOUR Beetle on them... | southerncarparts | Market Place Archives | 12 | 01-03-2006 01:22 PM |
| Monza Performance Cat Back Exhaust? | Beetlebomb | Technical Modifications | 0 | 12-28-2005 03:50 AM |
| Nobody looking in special interest area | FineExampl | Suggestion Box | 11 | 11-08-2005 01:56 PM |
| FS: GHL 3" Stainless Catback Exhaust | w00sh! | Market Place Archives | 33 | 10-13-2005 01:26 AM |
