CEL Help?! - NewBeetle.org Forums
Old 04-17-2010, 09:11 PM
FallinApartBoy's Avatar
I Want A 2.5T
Dayton, OH, USA
Default CEL Help?!
ok my car sounds like the timing is off and is a little sluggish. kinda sounds like a harley. i just took the tranny out to fix the flywheel bolts which stripped out and the rear main seal. these are the codes i am throwing. when i search i hear MAF a lot and some MAP sensor. Let me know if anyone has had these issues. i do have a 3" downpipe with a test pipe and an o2 spacer and have thrown one of the o2 codes the whole time but not sure which one.
P1297 - connection charger - throttle valve pressure drop
P0138 - heated oxygen sensor - bank 1 sensor 2
P0136 - heated oxygen sensor - bank 1 sensor 2
P0340 - camshaft position sensor "intake" circuit - bank 1
i do have my air/fuel gauge hooked to the rear o2 and just replaced the cam position sensor with a used one from someone local with no results. also replaced the DV with a forge 007 recently so i pulled it out and made sure it was functioning ok. i have the green spring in it with 1 spacer. i have it the way forge says on there site which is the quieter way with the top facing upwards.
Old 04-19-2010, 02:35 AM
I Want A 2.5T
Dayton, OH, USA
no one?
Old 04-23-2010, 05:40 PM
alexvilla's Avatar
beetle @lex
El Paso, TX, USA
Car: 1.8T
P1297
Connection turbocharger - throttle valve pressure hose
P0138 - heated oxygen sensor I bet you have a downpipe… change the 02 and put a spacer on it
P0136 - same ^^
P0340 - Timing belt my be loose… check your tension on it.
good luck
Parting out mods...
http://newbeetle.org/forums/new-beet...tml#post703989
COMPLETE VOTEX KIT FOR SALE!
http://newbeetle.org/forums/parts-ac...-kit-sale.html
I got another CEL but...... snoopy041824 Questions, Issues, Concerns, or Problems with the New Beetle 7 07-09-2008 02:55 PM
CEL on AGAIN! clowngrrl Questions, Issues, Concerns, or Problems with the New Beetle 10 04-02-2006 06:25 AM
CEL on Curves 1.8 Liter Turbo 6 02-01-2006 06:47 PM
!!! Cel Can Someone Help jon 2.0 Liter Gas 0 01-29-2006 03:09 AM
cel - on jon Questions, Issues, Concerns, or Problems with the New Beetle 0 01-26-2006 06:17 AM
