Engine idle problems - NewBeetle.org Forums
Old 04-25-2010, 02:19 AM
Owensboro, KY, USA
Car: 2001 GLX
Default Engine idle problems
I'm having problems running my nb. It starts up but the idle is all over the place. It revs up but I can tell there is something wrong. I have a V-checker Pro I got from ECS tuning. I checked the codes. I have three...
17967.P1559 Throttle valve control part- J388: fault in basic settings
17972.P1564 Throttle valve control part- J388: Insufficient voltage during basic setting
17579.P1171 Angle sender 2 for throttle valve drive- G188: Impossible signal
I've searched for a little bit online, but I'm not sure exactly the problem would be with all three codes.
Thanks,
Mikey
Old 04-25-2010, 04:15 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Check your throttle body/control module on the intake manifold.
My NB Family...
Old 04-26-2010, 02:42 AM
Owensboro, KY, USA
Car: 2001 GLX
I checked and I wasn't sure what to check, all the connections were tight. Not sure what else to check.
Thanks,
Old 04-26-2010, 11:52 AM
D2Beetle's Avatar
NB Yellow Trifecta
Did you take the breather hose off and look down the tube at the throttle body sensor behind the valve flipper? The throttle body also attaches to the intake manifold, the gasket could be bad.
Of course your throttle body could just be bad and needs to be replaced.
Old 04-27-2010, 09:25 PM
Owensboro, KY, USA
Car: 2001 GLX
It works!! I pulled the senser out in your picture. It was real nasty, so before I bought a new one I tried to clean it. And now it works perfect. I'm going to buy a new one anyway.
Thank you Very, Very much. I suppose the temp sensor was throwing everything else out of whack.
Thank you again!
Old 04-27-2010, 09:53 PM
D2Beetle's Avatar
NB Yellow Trifecta
Anytime, glad I could help.
check engine light, ruff idle, no code? Daisey 2.0 Liter Gas 2 09-29-2009 03:14 PM
Engine misfire, studder at idle/low gear, AC power outlets gone, door chime faulty... lokyee Questions, Issues, Concerns, or Problems with the New Beetle 3 09-28-2009 08:47 PM
NB can't keep idle and floods, yet throws a Engine Coolant CEL? XCman 1.8 Liter Turbo 6 08-27-2007 04:36 AM
Worst Case solution to rough idle problems XCman Questions, Issues, Concerns, or Problems with the New Beetle 0 08-26-2007 01:00 PM
Rough Engine Idle flybeetle 2.5 Liter Gas 4 04-12-2007 06:46 PM
