So when you picked your NB up at the dealer after the engine swap was it running properly then?
My NB Family... |
Hardey's MoToRwErKs- The only place to trust your VW/Audi to in Metro Denver
Yes it was running ok when I picked it up. The CEL was on though. It has been 2-3 years since the engine swap. also I might be confused about what engine code was in it originally but I know the one I have now is wrong. it is the engine from the Turbo S model.
If I understand correctly, some early model 2001's came with the APH motor.
When you say the turbo sounds like crap, please be more specific. Is it making a loud whooshing sound, like an airplane taking off? Could be the hose before the intercooler popped off. Happened to me once, swore I had some issues too with it. I'm not a mechanic, but replacing the ECM is more than likely pretty expensive. Before you go and do that, a few things I'd do: - Check all your hoses for bad connections, leaks, etc. - Check your intake and exhaust for leaks as well. They can set off a few of those codes, apparently. Would also lead to a change in sound on your car. - Remove the throttle body and spray it with a good TB cleaner. Carbon build-up can occur and sometimes leads to some of these problems. Even if the turbo was shot, which it doesnt sound like, unless you're looking at going with a big turbo conversion you can probably get a used K03 for less than what you'd pay to replace the vehicle. But if it isn't whats listed above it sounds like it could be an ECM software issue, or just a blown MAP sensor. But like I said, I'm no mechanic. I've just ran into the whooshing sound thing myself. ![]() |
not to double post, but why would you ever take a car home from a dealership with a CEL still up? Do you often let people take money from you and not complete their job? And why would you drive on a CEL and not get it looked into for 2-3 years?
| WTB: ko3 turbo, the cheaper the better | cisco | Parts and Accessories | 3 | 09-08-2008 03:10 PM |
| Cheaper Christmas Tree.... | SPIRU | Miscellaneous Hoo-Ha Archive | 31 | 11-20-2005 07:14 AM |
