Clutch is going... - NewBeetle.org Forums
Old 04-30-2010, 04:40 AM
newbugdude's Avatar
Costa Mesa, CA, USA
Car: '00 GLX
Default Clutch is going...
I have a 2000 Turbo. The clutch feels like its beginning to go. I changed my clutch in my old 70something beetle, but this looks scary. Is this a novice job, or should I start looking for a mechanic?
Old 05-05-2010, 01:54 AM
sledge0001's Avatar
CA, USA
Car: 2004 New Beetle Conv
I would pony up the bucks and make sure its done right... Too expensive to screw up in my opinion!
2004 NBC Pagparts Bottom Mount Turbo Kit W/GT3071R Turbo, 630 Injectors, ABD Intake Mani/ FMIC/ Water & Meth / Eurodyne Tune + Tiptronic to a 6 Speed Manual Swap!
http://www.adswap.com
Old 05-05-2010, 03:28 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
it's not hard, just time-consuming.
go to ecs, get a kit, done.
Old 05-05-2010, 04:16 PM
Clutch jobs on the front wheel drive VW's are not terribly difficult, but do take some time and require removing quite a few things to get enough working room. The job is much easier to do on a lift, but can certainly be done on jack stands. I've done them both ways and the jack stand route does require a little more "wrestling" with things.
For replacement options, the OEM clutch setup uses a dual mass flywheel, they are extremely expensive to replace. We have our Stage 1 Kits which convert over to a single mass flywheel that accepts a slightly larger clutch disc. They are a much less ex*****ve alternative to the OEM components, offer more holding power and retain the stock pedal feel.
Kits can be found here on the website:
Volkswagen New Beetle 1.8T > Drivetrain > Clutch
Old 05-07-2010, 10:13 PM
alexvilla's Avatar
beetle @lex
El Paso, TX, USA
Car: 1.8T
I have that ECS kit and its amazing... did my clutch myself and it is not hard at all, just time consuming and need a couple of extra hands... good luck
Parting out mods...
http://newbeetle.org/forums/new-beet...tml#post703989
COMPLETE VOTEX KIT FOR SALE!
http://newbeetle.org/forums/parts-ac...-kit-sale.html
Old 06-12-2010, 12:35 AM
nyum96's Avatar
HotLanta, GA, USA
Car: 01 Beetle 1.8T APH
Change the master and the slave clutch cylinders as well. I've gone through 3 master clutch cylinders and 1 slave cylinder. Replaced the clutch at 20,000 miles because of slippage.... 2nd clutch has 140,000 miles not issues. Replace the master and all is good again. Interesting.
2001 Beetle 1.8 for the straight roads.
1973 Porsche 914 for the curves.
clutch ETBUG 1.8 Liter Turbo 3 01-12-2010 01:29 PM
Clutch going out? Billsbug Questions, Issues, Concerns, or Problems with the New Beetle 23 08-13-2007 05:20 PM
Clutch AmandaErica88 2.0 Liter Gas 3 05-17-2006 03:48 PM
help with clutch... MandieGirl Transmission Talk 7 03-22-2006 04:26 PM
What is up with my clutch? chucksaysword Transmission Talk 6 12-02-2005 08:59 PM
