Battery? or Something more? - NewBeetle.org Forums
Old 07-15-2010, 12:42 AM
Greg
Minneapolis, MN, USA
Car: 04 1.8 Turbo with a kick ass color scheme
Cool Battery? or Something more?
Greetings. I went to start my car today after driving it to a work meeting and nothing happened but a clikkkkkkkkk sounds. Some of the dash lights were light up but eventually only the battery light and spoiler light would light up when i would try to start it. After an attempted jump start it still went clikkkkkkkkk with a small chug.
I decided to check the battery out.. all the cells were close to damn dry. I filled up all the cells. tried a jump and it started! drove it around for 15 mins or so. when i shut it off and tried to start it again it made the clicccckkkkkk sound with all the dashlights on.
So what i'm wondering is... is it just a needed new battery or something more? I have an 03 beetle and it's the original battery. Thanks much!
Old 07-15-2010, 12:56 AM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
Sounds the same as this:-
No idea what's happened.....HELP !! - New Beetle Owners Club
Old 07-15-2010, 09:01 PM
It certainly sounds like a failing battery not taking / holding a charge any longer.
Old 07-15-2010, 09:27 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Originally Posted by mpls_apple View Post
...drove it around for 15 mins or so. when i shut it off and tried to start it again it made the clicccckkkkkk sound with all the dashlights on.
That amount of charge into a flat battery won´t do diddly, the battery itself may or may not be totally shot (but I´d stake money it is), but to put some meaningful charge into a flat battery will need much more driving as a flat battery won´t take full altenator output as charge.
A better test would be to refill it then put it on trickle charge overnight...
Cheers
Simon
Old 07-15-2010, 09:32 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2010 Kia Forte EX 5spd AT Fuel Eco Opt
Yep. Battery is toast. Just had this happened to me and the battery was only 4+ years old. Get a battery at Walmart. Maxx 47 is what you need.
Old 07-16-2010, 12:39 AM
Greg
Thanks everyone! It was indeed the battery. I know because when i towed it home i checked the cells and low and behold..each one completely empty of water,,,,just acide left. I put distilled water in and jumped the car and its running fine. Still having a new battery put in tomorrow though
Battery Help! Smileybug 2.0 Liter Gas 1 09-21-2009 08:22 PM
Help - Need a new battery for my 1.8T! 2naFish Technical Modifications 4 11-02-2008 03:24 PM
Help - Need new battery for my 1.8T! 2naFish 1.8 Liter Turbo 0 10-14-2008 04:43 AM
battery C89ZX7R 1.9 Liter TDI 14 10-21-2006 05:06 AM
Do I need a new battery? SIX SPEED Technical Modifications 11 12-06-2005 04:53 AM
