I just bought a 2004 beetle with a 1.8 turbo engine when the engine is running at a idle has a lite rattel speed it up a little over idle it get louder speed it up just a little more rattel goes away and is very smooth sounds like its coming from the right side of the engine any ideas pulled the top timing belt cover off belt looks good
Cam chain tensioner. Common issue that you need to get fixed right away. When it fails it starves the lifters for oil pressure and damage can result.
Sounds like something is loose and tightens up when more tension is applied; check your timing belt roller and tensioner. The first pic shows you the TB belt path and the tensioner is above the roller.
Check the exhaust system all the way up to the turbo and manifold, make sure that all turbo to manifold and manifold to engine bolts are tight.
Get a hose or engine stethoscope and check the drivetrain until you locate exactly where the noise is coming from.
Did you do the water pump at the same time?
My news, after replacing the coolant temp sensor, thermostat, timing belt, timing belt tensioner, and water pump, found that my rattle was coming from the cam chain tensioner. This had better take care of my problem. Go figure my engine code takes the more expensive cam chain tensioner. We shall see where this leaves my rattle. Should have guessed this from the location of the rattle to begin with. Also changed the oil. I really don't want this to leave a bad taste in my mouth about VW, but I am really missing my Subaru SVX '97.
| Engine rattle | margie12 | 1.8 Liter Turbo | 4 | 06-12-2010 12:31 AM |
| Rattle under load | Smileybug | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 02-26-2010 12:06 AM |
| Rattle Proofing? | AbuNigel | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 02-04-2010 04:19 PM |
| rattle under the hood | angieisgroovy | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 06-08-2007 05:04 AM |
| Rattle and Hum.... | ImBuggin | Technical Modifications | 0 | 04-22-2007 12:15 AM |
