P0300, P0304, P0303 Codes - NewBeetle.org Forums
Old 10-27-2010, 04:04 AM
capnkt's Avatar
Sarasota, FL, USA
Car: 2001 GLS, 2003 Turbo S, 2010 JSW TDI
Default P0300, P0304, P0303 Codes
While driving my car this moring I had the CEL come on, and the engine started running very rough. I took the car home, and pulled the following codes P0300, P0304 & P0303.
Yesterday I had replaced the shift linkage with a Dieselgeek short shifter (awesome BTW) & accessed the bottom of the shifter mechanism (bad bushing at the shifter assembly). During this process I had the air filter assembly off of the car, as well as dropping a portion of the exhaust system to access the shifter linkage. Today I searched the car for anything I might have done wrong. I kinda expected to find something that wasn't re-installed properly, or a vaccum hose that was disconnected. Everything looked okay.
Where do I start?
Local repair shop?
Car is a 2003 Turbo S 1.8, 72,000 miles on car, TB & WP done by me
1000 miles ago.
Old 10-27-2010, 12:45 PM
Those are misfire codes. Spark plugs changed lately? Coil packs? The coils are under recall right now.
Old 10-27-2010, 02:42 PM
Fort Worth, TX,
Car: 2000 GLX
Not all Beetles have the coil pack recalls or so they say. I don't know why, they are all the same crap. My dealer told me my coil packs were not subject to the recall they may have been blowing smoke up my arse.
Go here and check, you need your vin #
VW Owners Portal < Volkswagen of America
Personally I think all the rubber hosing that decays and falls apart is worse then the coil packs and VW never did a recall for the hoses.
Old 10-27-2010, 09:52 PM
beetlekid's Avatar
Norfolk, VA, USA
Car: 2003 Turbo S
i had the same symptoms with my 2003 TS and it ended up being a misfire in cyl 4 caused by a bad coil once they replaced it all was well and my baby runs smooth!
mind you the car had 116,000 on it when this happened
2003 Beetle Turbo S Platinum Grey
Old 10-28-2010, 01:28 AM
capnkt's Avatar
Sarasota, FL, USA
Default Thanks for the replies!
I took your advice and called the local dealership. The car has two recalls that currently apply (coil packs & sunroof). I have an appointment for this Friday so we'll see if that takes care of it.
Thanks again for the help.
Getting 4 Error Codes Including 16684 P0300 and 16686 P0302 Ideas Appreciated rmwanga Questions, Issues, Concerns, or Problems with the New Beetle 7 02-10-2011 12:14 AM
Code p0304 and nothing else santafeguy74 2.0 Liter Gas 3 07-01-2010 08:41 PM
Code p0300,p0301. p0303 Autin3334 1.8 Liter Turbo 2 12-17-2009 03:53 AM
Code p0300,p0301. p0303 Autin3334 Questions, Issues, Concerns, or Problems with the New Beetle 1 11-28-2009 11:01 PM
P0300, P0302, P0303, P0304 newbluebeetle 2.0 Liter Gas 2 07-21-2008 01:10 PM
