Ok....somebody tell me they've seen this before!! - NewBeetle.org Forums
Old 06-10-2011, 05:54 PM
jonny1506's Avatar
BUGGIN'
Simpsonville, SC, USA
Car: 2000 1.8t
Default Ok....somebody tell me they've seen this before!!
I have included photo of inside catalytic converter. I swear it is a round honeycomb ball of material that everytime I would full throttle it would stick in exhaust end of converter causing lack of power and sounded like a wwssshhh sound like a vac or boost leak. One has already come out on its own with a big thud. Here's the other stupid ? how do i get it out and has anyone seen this before. Thanks
Old 06-10-2011, 06:45 PM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
Ummm, take it to a muffler shop and have then have them check it out for you? You may need to replace some parts of the exhaust; I'm sure once they cut into the problem area; the issue will be plain to see, what is going on... keep us informed on your repair! Good luck!
Old 06-10-2011, 09:03 PM
dmbluebeetle's Avatar
Blue Hunter
Riverside, OH, USA
Car: Blue '04 N. B. Turbo GLS
My first guess is that the material inside the converter is breaking apart, That used to be a big problem when converters first came out. The roundness would be due to the exhaust gases blowing by eroding the material.
Tags
1.8t , catalytic converter , exhaust , turbo
