i have a 2000 1.8 new beetle that i have a code p1426 and codep1602 the check engine light is on and my radio does nothing screen is blank checked fuses none are bad been working at this problem way to long can someone help where can i find a listing for the fuses in my in car fuse panel i bought this car 2 years ago thanks any help appreciated
i would like to thank you for yourpics they will give me another place i can look before taking to the stealer thanks again will post my findings thanks again for your help
If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
Terminal 30 means unswitched battery power that is supplied even when the ignition is off. This is not referring to any physical terminal numbered 30.
Looks like the second code relates to the battery, which could explain the radio problems. Take a good look at your cables and make sure they're good. Also looks like you have an EVAP issue, based on the first code. Hopefully this helps. I got this info from: Ross-Tech Wiki in case you want to investigate more.
Related Threads
VW Beetle Forum
979.7K posts
73.9K members
Since 2005
The New Beetle forum, come in and join our discussions on the new Volkswagen Beetle. Talk about modifications, performance and color choices.
