Oil Light Flashing... I couldn't find any threads. - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 08-29-2011, 03:59 PM
vdub00's Avatar
irishyardball
Austin, TX,
Car: '00 1.8t GLS
Ok so get this...
The turbo is functioning, i heard it spooling up around 2.8-3k rpm and it sounds normal, but the power seems off, maybe because i babied it the past week but i ran the codes and have nothing coming up but my ongoing SAI issue.
im going to get the codes checked again at lunch today, but maybe i should take it for a real drive before then so i can get a feel for how it is acting. the engine responds fine, the turbo seems like it might be sputtering a bit or maybe just trying to set itself right again, i dunno.
if anyone has any insight on this issue i would greatly appreciate your input.
'00 1.8t GLS
irishyarballs on vwvortex
I don't have a badge. I have a laminate.
  #22 (permalink)
Old 08-29-2011, 08:23 PM
vdub00's Avatar
irishyardball
Austin, TX,
Car: '00 1.8t GLS
Status update: My cruise control had gone out for some reason when this whole issue happened. it would not turn on no matter how much i tried. i just tried it again while driving to lunch and it worked fine. turbo seems to run fine as well. but i feel like i shouldn't be this optimistic.
Tags
flashing red light , lack of power , noise from engine , oil light
flashing red oil light middknight1 2.0 Liter Gas 7 10-23-2010 01:42 PM
Flashing ABS light, traction light, bouncing tach, and beeping terror_storm Questions, Issues, Concerns, or Problems with the New Beetle 1 09-21-2010 03:36 PM
brake light flashing/abs light on 74transporter 2.0 Liter Gas 5 04-05-2009 10:03 PM
Flashing Oil Light......Any Help? darkguyver82 1.8 Liter Turbo 21 12-02-2008 01:43 AM
ABS light on + brake light flashing Nounours Questions, Issues, Concerns, or Problems with the New Beetle 2 04-01-2008 10:45 PM
