Two days ago the check engine light came back on Yesterday it lost power and the EPC & ASR/ESP lights came on, it was barely running & wouldn't drive further so she turned it off & called AAA, they got the car home fine.
What I found when I got home was when you turn the key to start it sounds as if the starter is spinning by itself. When you lose a timing belt you can at least feel the bottom half of the engine turning. If indeed a timing belt I will need significant help with documentation and procedure to complete task, I can pretty much fix any car, just like to have as much info as possible so any PDF's and such are welcomed and appreciated. 2002 Turbo S, 104,000 mi Dave |
Pull the timing belt cover back some and have some one crank the engine over... does the timing belt move? If not, time to pull the cylinder head off. I've done this repair many times.
I would start here:
they have good prices on complete kits including the better water pump, tool rentals if you buy there kits and complete instructions. Let me know what you find out my 2003 Turbo S has but 3k miles more than you and although I have been told that the timing belt looks good it worries me. If the belt let go though you usually end up with severe problems as this is an interference engine (damaged pistons and valves). you can easily find out the condition of your belt by popping the cover off the top end of the engine on the belt side. Two spring clips are all that hold it on. You will see the top of the belt and the cam sprockets. Do you have access to someone with a Vag-com. You really need to pull the codes and see what happened. |
Got a buddy coming with a plain OBD2 so that should help a little I know I won't be able to see airbag stuff. I also really need documentation, anyone got some SW or pdf's for this car?
Thanks for the replies, I'll keep u posted |
Just popped the cover, the Timing Belt appears intact! But when you try to start car is as if the starter just spins, as doesn't engage. the TB has a little slack but if broke I would figure I could pull it out, which I can't
Does it sound like this guy's car when you crank on it?
AJ's VW timing belt broke, and watch him crank and bend the valves - YouTube Zzzzzzzzzzzzzzzzzzzzzzzzz That is bent valves, no compression. Without compression, the start just twirls the crank around without any problems so you get a smooth sound instead of the normal starting noise: ZraZraZraZraZraZraZraZraZra When driving down the road, if your starter just "fails", the engine doesn't die. When the starter fails, the engine doesn't crank over next time you try to start the engine. I've seen where timing belts shred off some teeth, get out of time, bend valves then gets a grip again and start spinning the cams. Remove the crank pulley and lower timing belt cover, look for shredded timing belt teeth. |
| 98 Beetle Loses Power while Driving!!! | littlekelly | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 05-05-2011 08:30 PM |
| 2006 Beetle POS loses power after driving for 2 hours | kduncan | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 04-11-2011 01:27 AM |
| Lets see your Christmas Tree(s)!! | squeebug | Miscellaneous Hoo-Ha Archive | 56 | 11-17-2007 09:38 AM |
| '99 NB 2.0 suddenly loses power & temporarily won't start | pjs28 | Questions, Issues, Concerns, or Problems with the New Beetle | 22 | 07-03-2007 09:32 PM |
| Who has their Christmas tree up? | SPIRU | Miscellaneous Hoo-Ha Archive | 135 | 12-22-2006 06:24 PM |
