inside the car but it is always good to change it once every couple of years. I still think it is either the heater core or perhaps the thermostat. Neither one of those two are easy to swap out in a 1.8T engine. Not sure exactally what this "Blend Door" is but I assume it has something to do with the direction the heat is directed like to the floor or to the vents or defrost? I suppose it would effect the way the heat comes out but even if I set mine to defrost it still eventually gets pretty toasty in my Beetle. Those seat heaters work wonders as well too warm up the core. On a cold day they are perfect at level 3 or 4. At level 5 I can feel my buns start burning ![]() |
You may have been thinking of mode control.
2000 GLS 1.8T "Pipi Langstrumpf" 2005 Vespa GT200L Granturismo "Senor Manetta" 1972 Triumph TR6R Tiger "Bettie" |
Now that the weather recently dipped cold here in Florida, I realize I have the "no heat" issue.
A/C is cold as ever. Blue coolant light goes out after about ten minutes of driving, I don't think the cooling fans are running either. When I pull off from a stoplight, I smell "heat" you know what I mean? ![]() [edit]Where should I start first? Last edited by newton27; 01-05-2012 at 02:18 AM.. Reason: added text |
| no heat, almost | dieselBB | 1.9 Liter TDI | 7 | 12-19-2011 11:51 AM |
| Got heat? | Downtown Turbo | The Canada Corner | 14 | 08-09-2010 02:04 AM |
| No heat | cjspack | 2.0 Liter Gas | 5 | 02-12-2010 03:33 PM |
| Still no heat!!!! | jailor8 | Questions, Issues, Concerns, or Problems with the New Beetle | 12 | 02-01-2010 09:00 PM |
| No HEAT!!! | jailor8 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 01-25-2010 09:10 PM |
