Engine assembly - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 12-27-2011, 04:06 AM
Check out Kuplaime's thread. There's more DIY pics to inspire you. Your color scheme sounds pretty sweet- can't wait to see your end results.
Sent from my SGH-T679 using AutoGuide.Com Free
  #22 (permalink)
Old 12-27-2011, 04:17 PM
LOUISVILLE, KY, USA
Car: 00 TURBO BEETLE
got my waterpump in today also orderd a splitter hybrid bov/dv
for the bug soon need to get a set of nice injectors will have pics of completed head soon.
im also having trouble removing the bolt that holds the harmonic balancer in place on the crank my impact wrench cant seem to get it loose any ideas?
  #23 (permalink)
Old 12-27-2011, 04:57 PM
IndyTom's Avatar
Indianapolis, IN, USA
I have the Forge Spillter valve and I like it a lot. It is set too stiff from the factory so turn it all the way counter clockwise and then turn it about 8 clicks clockwise to start out. Even with your set up I don't think you need it any tighter than 8 to 9 clicks.
As far as the Harmonic balancer goes. I would spray the bolt with some Seafoam Deep Creap Spray and let it soak in for a couple of minutes and than give it a try.
Good Luck!
  #24 (permalink)
Old 12-27-2011, 05:09 PM
IndyTom's Avatar
Not sure how accessible that Harmonic balancer is but you might just try a socket wrench and a hammer to shock it loose.
But I figure the impact wrench would be more powerful than a socket and a hammer but you never know. Do you have a puller once the bolt comes off?
  #25 (permalink)
Old 12-27-2011, 06:26 PM
Dipstick's Avatar
a guy with a car
ABQ,
Car: 2000 GLS 1.8T
i have a 1.8t that i rebuilt with new piston rings and rod bearing i was wondering what type of engine assembly lube would you guys prefer or can i just use lucas petrolium oil on the rod bearings
I've used STP Oil Treatment in the past and had good results with the engines I've rebuilt before. It is fairly viscous (viscosity means resistance to flow) and stays put during assembly.
That being said, I wouldn't use on turbo bearings (high viscosity may play heck on high rpm bearings) or oil pump (too viscous to insure proper pump priming). The STP will flow easier once the engine warms and essentially mixes in with the oil (which should be changed after engine has ran for some time).
It's also cheap and easy to find! Just remember to lightly coat the bearings with it, not smother them.
2000 GLS 1.8T "Pipi Langstrumpf"
2005 Vespa GT200L Granturismo "Senor Manetta"
1972 Triumph TR6R Tiger "Bettie"
  #26 (permalink)
Old 12-27-2011, 06:29 PM
LOUISVILLE, KY, USA
Got a pullie puller but not worried about getting the pullie off thats the least of my problems.. Need to remove the balancer to be able to time the engin. I can fit a socket on there but i cant get it off because the crank would keep moving i tryd to put the car in gear but nothing =/
  #27 (permalink)
Old 12-27-2011, 06:34 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
don't remove that center bolt... it's a stretch bolt and will loosen by itself if you take torque off it. remove the 6 or 7mm hex bolts around it... the balancer will come right off, and the actual timing crank gear will stay put.
  #28 (permalink)
Old 12-27-2011, 11:16 PM
LOUISVILLE, KY, USA
ty will try that tmrw
  #29 (permalink)
Old 12-30-2011, 06:47 AM
LOUISVILLE, KY, USA
got bored and did some work to the bug.. its true that these cars dont come with oil pan gaskets. what would you guys prefer i use for it
  #30 (permalink)
Old 12-30-2011, 03:13 PM
IndyTom's Avatar
Nice Work! If mine would look like that I would panic because I probably never would be able to put it back together
Use Victor Reinz Liquid Oil Pan gasket for the Oil pan.
D176404A2, Gasket Sealant - Oil Pan, secarpart.com
VW Oil Pan Sealing Compound Liquid Sealant - gasket on eBay!
  #31 (permalink)
Old 12-30-2011, 05:08 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Nice pics!
My NB Family...
  #32 (permalink)
Old 01-02-2012, 04:14 PM
LOUISVILLE, KY, USA
i got this 60hp wet kit for 325$ comes with auto bottle openee, bottle heater, nhra blow off purge kit with a full 10lb bottle. this kit usually gos for atleast 1,000$
  #33 (permalink)
Old 01-02-2012, 05:30 PM
Waterloo, ON, Canada
Car: 2000 1.8L NGS
Dude, did you hone those cylinders with the pistons installed?
2000 VW Beetle 1.8 145.000KM
  #34 (permalink)
Old 01-03-2012, 01:14 AM
LOUISVILLE, KY, USA
NOO! lool i got more common scence then that. i replaced the piston rods with eagle 4340 h beam rods with new rod bearings and new piston rings
  #35 (permalink)
Old 01-04-2012, 02:04 PM
LOUISVILLE, KY, USA
heads are almost done
  #36 (permalink)
Old 04-05-2012, 08:13 PM
LOUISVILLE, KY, USA
hey guys iv been putting in a little work on my beetle and im reddy to put the head back on i was wondering if there is anyone that can get me the timing marks for the crank and the head, iv tryd looking online but i couldnt find anything thank you. its a 00 vw 1.8t i think its aph
  #37 (permalink)
Old 04-05-2012, 08:19 PM
IndyTom's Avatar
Here is a Great Timing Belt DIY
VWVortex.com - Ultimate Timing Belt DIY!!
  #38 (permalink)
Old 04-05-2012, 10:02 PM
VDubYah's Avatar
Orlando, FL,
  #39 (permalink)
Old 04-07-2012, 01:42 PM
LOUISVILLE, KY, USA
i see where his camshaft lines up on the valve cover but i didnt see anywhere where the crank lines up, i pulled the little plug on the transmission so i can see the marks for the crank but i cannot see any special marks on the flywheele
  #40 (permalink)
Old 04-07-2012, 04:31 PM
VDubYah's Avatar
Orlando, FL,
Here are the trans marks for timing
98 Shifter box/assembly/cables upgradeable to 2000+ assembly? stage12 Transmission Talk 2 10-07-2011 11:47 PM
Tie rod assembly dannull Technical Modifications 1 08-12-2011 01:51 AM
Anyone have a right side fan assembly? green02turbo 1.8 Liter Turbo 0 06-24-2006 05:06 AM
Assembly of my RSI body kit moyo Styling Modifications 14 01-14-2006 07:27 AM
FS: KILLER SWAP - R32 Engine Assembly with harness and ECU BVA Market Place Archives 2 10-31-2005 02:49 AM
