2003 Shifting hard - NewBeetle.org Forums
Old 01-11-2012, 08:59 PM
BB2000's Avatar
East Haddam, CT, USA
Car: 2003 1.8 Turbo Convertible
Exclamation 2003 Shifting hard
Hey all! I have been experiencing some gear shifting problems with my '03 convertible. It's an auto trans, but when it shifts gears (both up and down) it jerks to some degree, sometimes really noticeably and sometimes not so much. I'm hoping that maybe it's just the crappy gas I use sometimes; I filled it up today with the expensive grade at a Shell station and it seems to have calmed down quite a bit. Could it be something more serious? Obviously can't check the tranny fluid without letting the idiots at the dealership assault my wallet. My baby just hit 100,000 so I'm concerned that she's getting old and tired. I try to take good care of her on a budget. Any advice for cost-effective fixes?
"This is still my life/not yours to define"
-Emery, In a Lose, Lose Situation
Old 01-11-2012, 09:01 PM
Fluid and filter change on the transmission would be my start. At 100k, it could use it. If that doesn't fix it, you are likely looking at a valve body failure in the transmission. Very common in the VW automatics.
Old 01-11-2012, 09:08 PM
BB2000's Avatar
Is it possible to do the transmission fluid & filter at home? My bf usually does my oil changes and other minor work; being a motorcycle mechanic, he's pretty handy. And is the valve body failure expensive to fix?
Tags
engine , transmission issues
extremely hard shifting on automatic!! need help!! mbz03 Transmission Talk 3 05-30-2010 03:17 AM
EXTREMELY hard shifting...possible tranny problem? calamitydown Transmission Talk 5 11-20-2009 11:14 PM
Hard shifting in to 1st gear and second mike 51 Transmission Talk 0 08-13-2009 09:29 PM
Hard shifting razorbug Questions, Issues, Concerns, or Problems with the New Beetle 8 04-01-2009 02:10 AM
