But it is quite possible that starters go out without any warning.A lift won't do you much good unless you use it to swap out the starter Just from looking at it you can't tell if it is good or bad. It's most likely the voltage regulator that went out. You could take the starter off the car and have it tested. That way you can be certain prior to spending money on a new one. Good Luck! If I were closer to NC I would come and help you. |
Hello, fellow NC'er! What shop did you take the car to?
Haha, I can type faster than Smileybug and IndyTom. But I do think we may have made tech16204 angry..lol. He stopped talking..
Live a Life of Serenity, Not a Life of Regret. Current NB 2002 GLS Double Yellow "Pixie" Previous NB 2000 GLX Black "Little Ed" "Other" Road Trippin' Ride 2010 Dodge Challenger Bright White "Baby" |
Yup, there is a difference between the Automatic transmission and the manual transmission starter:
Here is a rebuilt BOSCH unit from ECS tuning for the manual transmission. Volkswagen New Beetle 1.8T > Search > Starter > ES#263742 Re-Manufactured Starter Motor - SR0425XKT Here is one for a little over 70 bucks. http://www.primechoiceautoparts.com/...1429-mmy-.aspx It says 1.8L except turbocharged engine S. Since all 1.8L engines are turbocharged I think they are trying to say except Turbo S models. Or it is simply a missprint. Last edited by IndyTom; 01-25-2012 at 01:38 AM.. |
I just dealt with my fiance's beetle not wanting to turn over. We were on the way out to eat and it just died at the light. Like you I didn't want to spend any unwanted money or take it to the dealer.
I check every relay and fuse, the fuel pump was running, tested the alternator and battery. All I didn't check was the starter and ignition switch. I ended up buying the crank position sensor and swapped it out. Cranked over instantly. The symptom I had were that it abruptly died at a red light. Wouldn't start up after that. Wouldn't take a jump. Had to get it towed to the house and went from there. Hope you get it fixed soon! |
While reading thru this thread, I noticed a couple of comments about the Voltage Regulator being on the starter? When did VW "start" doing that??
As suggested, check all the wiring connections at the battery, including those on the starter......loosen and re-tighten each connection. If it is a plug-on connection, unplug and re-plug! As suggested, check the clutch switch function also. If it doesn't work, during the start position on the ignition there will not be any "current" to the solonoid at the starter....I think that wire is a plug-on. You need help and use of a multimeter to check the voltage at the solonoid with the clutch depressed and ignition in the start position to do that. I'm not sure whether or not your vehicle has the immobilizer(forgot the title of this Thread and info since I began reading and typing). But, if it does, there could be an issue with it. I cannot believe that a sensor such as the Crankshaft Position Sensor would keep the starter from turning the engine over. Hope this helps!
2000 Jetta TDI (diesel) 50.1 mpg life-time ave 300,000 miles on 12/28/11 |
| help me car wont start | Karelli4bugs | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 09-17-2011 12:44 AM |
| 99 1.8 NB wont start | tejam003 | 1.8 Liter Turbo | 1 | 10-03-2009 02:12 PM |
| car wont start | mat3833 | 1.8 Liter Turbo | 6 | 02-10-2009 03:16 AM |
| wont start | nastylefthook1 | 2.0 Liter Gas | 1 | 11-07-2008 04:35 PM |
| Empty tank and wont start - 2003.5 1.8T | digitalputty | Questions, Issues, Concerns, or Problems with the New Beetle | 11 | 12-29-2006 06:52 PM |
