What makes you think its not the MAF? Just curious really.
I don't have any problems with the idle or hesitation or stalling. I'm not throwing any lean or rich codes. I just knew by the way it was driving it was a boost leak.
Took it to a local shop I'm friends with, got it up on the lift and after 30 minutes of searching, we found what may be the issue, something not tightly clamped on. I'm still at the shop as I'm writing this, so ill update in a bit to confirm this was the issue. If it isn't, a leakdown test is in order. On the sucky side, found out my turbo is leaking oil and coolant. not bad, something I just need to keep an eye on and prepare to replace it in the next year or so.Last edited by Oh Randi; 01-26-2012 at 03:07 AM.. Reason: I can't spell |
My diverter valve is the forge 007, properly oiled and maintained. No rubber diaphragm to rip like the OEM one. It sounded like it was operating properly, and with my short ram intake believe me you can hear it. The leak sounded WAY different than a blown DV (which sounds like a honking noise, ask me how I know lol).
I do not have a boost gauge, however I do have my VCDS software which I used for some quick data logging. Boost was within spec until it got close to 7 or 8 psi ( pretty close to full boost for stock) which is when I heard the noise. So we started poking around under the car for leaks and BAM, there it was. The clamp on the elbow right off the turbo that connects to the turbo outlet pipe was just chillin there, not clamping anything. I think it was on vacation Tightened the clamp and took it for a drive. All was well. I am not mechanically inclined whatsoever. I learn new things about this car every day. My testing procedures aren't the best, in aware, but I really had a gut feeling about it being a boost leak, not the MAF. I just thought I'd post my experience here for others to learn from, And maybe prevent someone from wasting money on a new MAF, and deciding to sell the car when it doesn't fix it. |
![]() I once had the same issue on my Audi TT. Back then I didn't know better and took it to the dealer. They couldn't figure it out for over 5 days, then finally replaced that little elbow hose comming of the Turbo and charged me 800 bucks for it. From that point on I never took it back there again and made it a point to learn more about these cars. Have a fabulous day! ![]() |
IMO, we don't have enough threads on here where people actually follow up on the solution. So, everything I encounter that may help someone else out, I will come back and post about. I like having a discussion with people throwing out options, and eventually stating the solution. It's very helpful for people that just like to lurk and get ideas to help them troubleshoot. |
| A couple questions, P0112, P0422, P0103, P0102 | sweetpea4e | 2.0 Liter Gas | 0 | 01-26-2011 06:25 PM |
| Help, please - I have searched to no results...P0103, P0422, P1127 | sweetpea4e | 2.0 Liter Gas | 10 | 01-21-2011 05:18 PM |
| Adventures in backing out of driveways | branvan | Questions, Issues, Concerns, or Problems with the New Beetle | 18 | 06-12-2008 02:18 PM |
| Buglover and Doobies Great Adventures | Buglover | Miscellaneous Hoo-Ha Archive | 9 | 10-17-2007 09:13 PM |
| The further adventures of Normski... | PaulD | Photos: New Beetles | 12 | 01-24-2006 06:59 PM |
