I need opinions on brakes! - NewBeetle.org Forums
Old 01-29-2012, 02:18 AM
Oh Randi's Avatar
<---- not a boy.
Tulsa, OK, USA
Car: 2001 1.8T, slaughtermatic.
Default I need opinions on brakes!
So, the time has come for me to replace my brakes. My mechanic informed me, while looking for that pesky boost leak, that my brakes are terrifying and need to be done ASAP. apparently the pads are almost down to metal and soon ill be looking at rebuilt calipers and my rotors are worn out pretty bad too. I've owned the car for 4 almost 5 years and I think the brakes are the only thing I've never messed with. That said, I know nothing about them. He recommended Wagner thermoquiet pads I believe, saying they're quiet and light on the brake dust (which is important to me!)
This is going to sound silly, but I want cool looking rotors. I like the vented look. Anyone have any suggestions for any brand? I'd like something that lasts and looks nice without being TOO crazy expensive.
Also, I know VW recommends changing the brake fluid every 2 years regardless of mileage, I know it's been at least 4, and knowing how horribly the PO took care of the car, I'm willing to bet its never been done. Would it be a good idea to do this at the same time?
Originally Posted by janitz View Post
Now I've got this strange image of someone sticking their nose between the spokes on the tires and taking a big sniff and then saying, "I love the smell of brake dust in the morning, it's the smell of victory."
My VW is perfect, instead of diesel fumes it farts sunshine and rainbows.
Old 01-29-2012, 02:49 AM
Drilled / slotted rotors and low amounts of brake dust are mutually-exclusive. Anything but blank rotors is going to wear the brakes faster and create more dust.
I've never heard of that brand of brake pad before, is the mechanic the one who can order them in for you?
Mechanics are prone to recommend parts they can make money from. If you're looking for recommendations for a brake setup I'd recommend OEM or Brembo blank rotors and EBC / Hawk pads. Both claim to have low dust.
For daily cars that don't have fancy wheels I actually like OEM pads. They're relatively cheap, last a long time are quiet but they definitely make dust.
Boost Master D's Avatar
2005 1.8T
Austin, TX, USA
Car: 2005 1.8T gls
I'm not sure of your budget but I ran across a set of front slotted rotors for $400 dollars last night. I need to go back in my history and see what they were ( I didn't pay too much attention) because I wasn't looking for brakes when I ran across them. My thought is this,...if your doing the brake pads and rotors, why not change or flush the system. Excellence is in the details, and if you are overdue its time anyhow. Let me find those rotors and I will get a link up for you soon.
cheers
Old 01-29-2012, 02:51 AM
Good god... OEM blanks are like 100 bucks a pair. Screw that.
Old 01-29-2012, 03:00 AM
2005 1.8T
Austin, TX, USA
Car: 2005 1.8T gls
Haha yeah a bit pricey,..Im sure there are cheaper ones. I just ran across those by accident.
Old 01-29-2012, 03:10 AM
Oh Randi's Avatar
<---- not a boy.
Tulsa, OK, USA
Lol my mechanic is actually a personal friend that happens to own a VW repair shop, he's not making a dime from this as I'll be doing it myself. He said he uses those pads on both his jettas. He wouldn't try and get me to buy something to make money off me, especially considering I'm not buying through him. I asked him what I could buy from O'reilly's because I get the employee discount there.
I'd ideally like to pay no more than $500 for fronts and rears. I was just needing some good brands to be tossed out there because I've never bought brakes before.
Old 01-29-2012, 03:35 AM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
MJM has some nice packages; I think the classic German brands like Meyle, Zimmerman, Ate, (brands used by VW) are safe bets, check out some options:
MJM Autohaus
Old 01-29-2012, 03:41 AM
Read my post again if you missed my recommendation.
Old 01-29-2012, 05:16 AM
IndyTom's Avatar
Indianapolis, IN, USA
I would stay away from Slotted and Drilled Rotors. Cheap ones can develope microfractures over time and crack. The good ones are expensive and on a beetle really not necessary. If you want some looks in that department I would paint the calipers. That always makes them stand out and brings attention to the wheels. That said. EBC does make some decent slotted rotors that are perfectly safe and look GREAT. As SMG already mentioned with any slotted or drilled rotors comes more brake dust. I did all my brakes in April of 2011 and used EBC vented but solid disks and EBC Ultimax Brake pads. All 4 Rotors and Pads only cost me around 180 Dollars. I did change out the fluid and painted my calipers at the same time and I can say that so far I am very impressed with the brake performance and low dust of the EBC pads and rotors.
If you want a to spend a bit more you can get the EBC slotted Rotors and the EBC Green Stuff or even Red Stuff pads.
You can't go wrong with EBC brakes.
http://www.autopartswarehouse.com/sk...html?loc=Front
Complete set of EBC Ulitmax Black Dash Rotors plus EBC Redstuff Ceramic Brake Pads : $395.07 That would be a GREAT package. For EBC Solid Rotors and EBC Ulitmax Pads it's less than half and they are still GREAT brakes!
Old 01-29-2012, 03:12 PM
LiftedBeetle's Avatar
ME, USA
Why would you need new calipers just because the pads are low? Did the pistons get pushed completely out of the calipers? I doubt it, as that would be pretty noticeable. (loss of fluid and no firmness to the brake pedal)
Old 01-29-2012, 03:38 PM
Oh Randi's Avatar
<---- not a boy.
Tulsa, OK, USA
I don't need new or rebuilt calipers YET, he was just letting me know he didn't want me to drive on those almost non-existent pads, or else that could happen. I've been needing to do my brake for at least 6 months now. It doesn't seem like it wants to stop very easily when I have to stop quickly. I'm easy on the brakes so never noticed they started sucking until I had to stop very quickly to avoid a dog.
Anyone else think EBC makes decent rotors? I looked at them, given the price I thought they'd be better than some of the really cheap ones.
Old 01-29-2012, 04:16 PM
IndyTom's Avatar
EBC Rotors are some of the most High Grade Rotors made, period.
They aren't made in China or who knows where like some of the other Rotors out there. They are made in the UK under the highest quality standards. You can pay a higher price for other brakes but you won't find better brakes made out of the highest quality materials at any price than EBC.
EBC Brakes Corporate Video - YouTube
If you want to spend more money than get the EBC Sport Rotors. They are highly rated and are dimpled and slotted. Very nice rotors! Couple them with the EBC Red Stuff Ceramic Pads and you will have an Excellent combination. Front and Rear EBC Sport Rotors along with EBC Red Stuff pads will cost you around 500 or a little more. So I guess that would still be in your budget. Personally, I think it is overkill for a Beetle unless you just like to spend the extra money on the way the rotors look. For around 180 bucks you can have quality Rotors and pads that will last you just as long and stop the car just as quick with a lot less Brake dust than any slotted or drilled rotor set up. http://ebcrotors.com/p-223-ebc-sport-rotors.aspx
Whatever brakes you decide to go with promise me you won't go with some cheap Chinese type or rotors. They may look nice in the beginning and may even work well for a time being but then you will hear more squeeking and they will rust and they will crack and that could be very dangerous! Stay with Quality rotors like EBC or Brembo or Centrix.
Old 01-29-2012, 04:36 PM
Oh Randi's Avatar
<---- not a boy.
Tulsa, OK, USA
If you want to spend more money than get the EBC Sport Rotors. They are highly rated and are dimpled and slotted. Very nice rotors! Couple them with the EBC Red Stuff Ceramic Pads and you will have an Excellent combination. Front and Rear EBC Sport Rotors along with EBC Red Stuff pads will cost you around 500 or a little more. So I guess that would still be in your budget. Personally, I think it is overkill for a Beetle unless you just like to spend the extra money on the way the rotors look. For around 180 bucks you can have quality Rotors and pads that will last you just as long and stop the car just as quick with a lot less Brake dust than any slotted or drilled rotor set up. EBC Sport Rotors | EBC Dempled and Slotted Sport Brake Rotors
I was actually looking at this combination:
EBC Redstuff Pads
and either these rotors
or these.
Can you tell me which are better?
It appears I can get them both special ordered from O'reilly's which is great. Much cheaper for me!
Old 01-29-2012, 04:49 PM
IndyTom's Avatar
EBC Redstuff Pads
or these.
You can't go wrong with either one. I would go with the first set (Sport Rotors). I think you will like them better since they do have dimples and slots and they are very High Quality.
They are a little more expensive than the Ultimax Black Dash Rotors but the Sport Rotors will look better on your Beetle and they are Great Rotors especially with the Red Stuff Pads. The Ceramic Pads should minimize brake dust but sometimes they can squeak a bit but if you break them in properly you should be fine. Go for it!
Old 02-09-2012, 02:29 PM
Oh Randi's Avatar
<---- not a boy.
Tulsa, OK, USA
I'm back! Ordering the 3GD sport rotors and redstuff pads tomorrow when I get paid. $385 for everything isn't too bad!
Now, I've never broken in new brakes before.. does this sound right?
ECS tuning brake bedding procedure
any tips?
Old 02-09-2012, 03:14 PM
IndyTom's Avatar
Good Choice on the combo! As far as breaking in new brake pads. EBC brake pads have a special coating that makes them easy to break in. Just use common sense and don't take the car on any Rally Races for the first 500 miles and you should be fine.
Old 02-09-2012, 03:24 PM
Oh Randi's Avatar
<---- not a boy.
Tulsa, OK, USA
Cool beans. I tend to overanalyze things and I don't want to mess anything up, especially something costing almost $400 lol. I'm always extremely easy on my brakes anyway, so I guess I shouldn't have much to worry about.
Old 02-09-2012, 03:28 PM
mullardel34's Avatar
Midwest US, USA
Car: 2000 GLS Turbo
The ECS brake bedding-in procedure looks to be spot-on. Just keep in mind that during the brake bedding-in process, that you're objective is to very evenly transfer brake-pad friction material to the rotors in order to permit the brake-pads to properly grip the brake rotors. So don't come to a complete stop while applying the brakes when you've got the brakes up to temperature. Otherwise, you could end-up transferring a "ridge" of friction material onto the brake rotors that will cause a rythmic pulse/bump while braking (and it's damned-near impossible to "smooth things out" without machining or replacing the rotors).
So, when doing the series of 60mph-to-10mph controlled stops, remember to release the brakes before you come to a complete stop and avoid coming to a complete stop with the brakes appled until the brakes have cooled-down. You're going to really smell the brakes duing the brake bedding-in process, so don't be alarmed.
Good luck!
Mullard EL34
Klaus --- 2000 Volkswagen New Beetle GLS (1.8L 20V turbo) w/ 5-speed manual transmission
Sport Edition F7 wheels (16"x7")
Continental ExtremeContact DWS tires (205/55ZR-16)
Old 02-09-2012, 03:34 PM
Oh Randi's Avatar
<---- not a boy.
Tulsa, OK, USA
Good luck!
wait, so, I should brake until going maybe 5 or 10 mph, coast to almost a complete stop to allow brakes to cool then apply brakes if I need to? like if I'm rolling forward or backward?
thanks for mentioning I'll smell the brakes.. I didn't know that and would probably panic thinking I did something wrong lol
Old 02-09-2012, 04:22 PM
This is something I believe I'd like to do as well coming up this summer.
In addition to the pads and rotors, will we need to purchase any other parts that are supposed to be replaced when doing this kind of work?
I need some opinions........ mandy Photos: Other Rides 28 05-03-2007 08:59 PM
Need some opinions on this Dragonspirit12 Styling Modifications 12 02-21-2007 02:54 AM
I need some opinions! Netty310 Miscellaneous Hoo-Ha Archive 2 08-25-2006 02:06 AM
Others opinions... cnowak88 The New Beetle Experience 17 04-25-2006 02:54 AM
Need some opinions on brakes beetleguy Technical Modifications 2 10-26-2005 03:32 AM
