Diverter question - NewBeetle.org Forums
Old 02-03-2012, 07:15 PM
ghettoracer's Avatar
VDub Noob
Klamath Falls, OR, USA
Car: 2002 VW New Beetle Turbo S
Default Diverter question
Does the stock 2002 NB TS have the 710N diverter valve? Mine is Bosch but I cant see the other side of it. Just has a 040 in a circle on the side that faces me. Any input would be appreciated. Thanks
Throw your Dubs up!
2002 VDub New Beetle Turbo S- BONE STOCK
1997 Ford Expedition Eddie Bauer- Need I say more? It's a FORD
2003 Nissan 350z 6spd- 4.2L Bi-Turbo swap, my street car
Old 02-03-2012, 07:46 PM
IndyTom's Avatar
Indianapolis, IN, USA
If it does have the 710N it wouldn't be the stock Valve since I don't think it was out yet in 2002. But it could have been swapped out at one point.
Here is a link to ECS tuning Bosch 710.
Volkswagen New Beetle 1.8T > Search > Diverter Valve > ES#581 Diverter Valve, 225hp Audi TT Version-Priced Each - 06A145710N
Old 02-04-2012, 04:12 PM
VDub Noob
Is the 710 throttle response better than the stock TS diverter?
Old 02-04-2012, 05:52 PM
IndyTom's Avatar
Not really. The diverter valve doesn't do anything in regards to throttle response. It either works or it doesn't. The 710N is just a bit more durable and can easily be used along with higher boost as with a Tune or chip. The stock valve is known to fail shortly after a tune has been performed on the car.
For slightly better boost and low end performance you can get a N75 Race Valve. It will hold boost longer and on average will spike about 3psi higher than stock. I am using one in conjunction with my REVO Stage1 tune and it works really well.
Diverter valve? mskiba2 1.8 Liter Turbo 13 01-15-2012 02:55 PM
Diverter valve question/who has a good one? BLOWNSVT1 1.8 Liter Turbo 11 09-05-2011 08:01 PM
Diverter Valve question! VeeBugTurbo 1.8 Liter Turbo 3 03-13-2009 04:08 PM
B.O.V/Diverter ?'s newbie 1.8 Liter Turbo 5 02-24-2009 01:28 PM
New Diverter Valve, Thanks! Oyveychris 1.8 Liter Turbo 20 05-22-2007 11:11 PM
