misfire issue - NewBeetle.org Forums
Old 02-04-2012, 01:52 PM
Car: 2001 VW beetle GLS 1.8t
Default misfire issue
hello all,
I have an issue with my 00 beetle 1.8t 5 speed. It started to misfire yesterday on my way back to work. I got two codes out of it p301, p303 which is misfire on cylinder 1 and 3. I have changed the plugs and switched the coils around to see if the coils where bad. what I mean by that is #1 coils went to number 2 and #3 coils went to #4. I started it up and then still got the same codes misfire on cylinder 1 and 3. I am using ngk pfq6r (recommended by vw) spark plugs. does anyone have any ideas on what it could be.
Old 02-04-2012, 01:54 PM
Did you gap the plugs correctly? How is the coil wiring?
Old 02-08-2012, 08:56 AM
ghettoracer's Avatar
VDub Noob
Klamath Falls, OR, USA
Car: 2002 VW New Beetle Turbo S
Did you unplug the battery before you changed the coils around?
Throw your Dubs up!
2002 VDub New Beetle Turbo S- BONE STOCK
1997 Ford Expedition Eddie Bauer- Need I say more? It's a FORD
2003 Nissan 350z 6spd- 4.2L Bi-Turbo swap, my street car
Old 02-08-2012, 11:38 AM
esse10's Avatar
Richmond, TX, USA
Car: 03 1.8 Turbo
Default misfire
Did you see any oil at all in the plugs well?
The last time I had a misfire was because oil was leaking into the spark plug well and causing problems with 2 or 3 plugs. i just had to replace the valve cover gasket, no problems ever since. good luck man.
Old 02-08-2012, 01:33 PM
Why would you need to unplug the battery? Just did the spark plugs on my GTI a few weeks ago...no unplugging of the battery and everything was just fine.
misfire issue jcthelight 2.0 Liter Gas 36 10-14-2010 12:41 AM
Misfire on 2 & 4... Trickyslick 2.0 Liter Gas 3 07-31-2010 07:53 PM
Misfire #3 buzzard217 2.0 Liter Gas 5 11-08-2009 03:23 AM
misfire issue, Coolant lead? snaporange 1.8 Liter Turbo 2 05-28-2008 12:41 AM
Alarm Issue and Inside Light Issue-HELP! tinarie01 Questions, Issues, Concerns, or Problems with the New Beetle 4 01-02-2007 06:36 AM
