Spark Plug Wires? - NewBeetle.org Forums
Old 03-06-2006, 04:05 AM
jesse's Avatar
Toronto, Canada
Default Spark Plug Wires?
I went to go buy factory spark plugs and wires the replace mine. The guy at the store told me that the 1.8T doesn't have spark plug wire, i only has spark plugs. Is this true?
Old 03-06-2006, 04:21 AM
yelojkt's Avatar
beetle driver for life
Wichita, KS, USA
Yes that is true. Instead of having a coil; distributor; and plug wires...each plug has its own coilpak plugged onto each sparkplug. Much more efficient. They are under that plastic engine cover.Depending on what year you have you can remove it by hand or with a 10mm socket.
Moded to make driver grin.
Did You see Yelojkt?
Dyno Video before custom K03S
09 ZX6R Candy Blue
Old 03-06-2006, 04:25 AM
v-dubed's Avatar
my turbo is bigger!!!!!!!
crap hole royse city , TX, USA
Car: 02 black sport
oOo i have spark plug wires : ) but im special heeh
03 evo vIII 2.3 gt35rhta...
93 eagle talon awd gt42
91 talon gt35r dd
08 cbr1000rr
1000hp club!!!
Old 03-06-2006, 05:15 AM
jesse's Avatar
Toronto, Canada
i have a 2001. I need to change my spark plugs. Can i just pop them out and put the new ones in? do i need to change anything thins else? Thanks for the help!!!!
Old 03-06-2006, 09:14 AM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
It's not quite as easy as that. you have to remove a couple of things and loosen and disconnect the coilpacks to get at the plugs.
(\__/)
(")_(")
Me: www.myspace.com/beetlenut
Old 03-06-2006, 06:16 PM
jesse's Avatar
Toronto, Canada
do the coilpacks need changing? Or do i just replace the spark plugs. THank you very much
Old 03-06-2006, 07:02 PM
yelojkt's Avatar
Wichita, KS, USA
Is your car running poorly? Why are you changing the plugs in the first place? How many miles do you have on your car? No you should not have to replace the coilpaks unless you have a bad one. I've read of people getting VW to pay for their new coilpaks because there was a problem with some of them, I don't know much more than that maybe someone can elaborate.
Old 03-06-2006, 08:20 PM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
No, coilpacks don't need to be changed unless you are getting a flashing C.E.L. with stumbling and poor acceleration. I wouldn't try to get fancy with the replacement sparkplugs though. Mine really likes the factory installed NGK's and I've heard from several different sources that it's not a good idea to try to run a "hotter" plug, although I'm not certain on that point.
Trailer light plug? How to attach wires? Love Machine Technical Modifications 2 02-13-2006 08:07 PM
Spark Plug wire question for the newbie. Grand_Prix_Guy 2.0 Liter Gas 8 11-29-2005 06:27 PM
Spark wires - Do I need to remove the manifold? [lot] 2.0 Liter Gas 17 11-21-2005 05:51 PM
Spark Plugs SIX SPEED 1.8 Liter Turbo 25 11-19-2005 01:34 AM
Problems changing plug wires & fuel filter. jent 2.0 Liter Gas 8 10-10-2005 08:04 PM
