1.8T Engine APH/APW Swap Issues - NewBeetle.org Forums
Old 11-16-2012, 08:08 PM
Kula191
Car: 1999/00 Beetle 1.8T
Default 1.8T Engine APH/APW Swap Issues
Hello all,
I acquired a 1999 Beetle w/APH that was blown, timing belt ripped..bent the valves ..etc. I acquired a 2000 Beetle w/APW and stripped it to a shell. I have successfully installed the Engine and Train but have encountered numerous issues.
Currently i cannot get fuel to the engine. Fuel pump not actuating as if there is no power there although the 15amp fuse constantly blows. Engine cranks w/o issue.
I do need to mention a couple things that occurred prior before the engine swap when the APH was still installed and occurred prior to ripping anything out..
With a battery charger (that will start a car) was able to power up everything.. lights/radio/blower etc testing the electrical prior to the swap..an attempt was made to turn over the engine not knowing if all the valves were shot.. what happened.. a pop.. and a couple fuses blew. Proceeded w/the Engine swap.. once we got it in had some electrical issues.. Interior cabin lights flickering on/off after a couple min.. the fuel pump not actuating.. checked the grounds per bentley book.. found a potential bad ground under the driver side headlamp.. fixed & added a grounding strap between the neg term and the ground on the chassis.. light issue went away.. still have no radio or fuel pump. Swapped 409 relay as well.. fuses arent blowing anymore.. Fuel gauge on pump works... if i move it shows empty or full.. Quite possible that the fuel pump is shot although when connecting power directly to it humms/whirls but not when connected to the harness .. but i'm stuck.. thinking blew a main relay?> ECU problem? Inline fuse? I appreciate any input! Thanks.. (did run odbII on it.. ECU checks ok) HELP please!!
Old 11-17-2012, 01:01 AM
Krash's Avatar
Murfreesboro, TN,
Car: 2002 Turbo S - 2003 Turbo NBC - 2010 TDI Cup
Are you sure about the year and engine models you have? of corse stranger things have happened but a 2000 should have been an APH also, a 2001 could have an APH, AWV, AWP depending on the model of the beetle.
What ECU and wiring harness are you using?
The APH and AWP motors use different ECU's and wiring harness and are not 100% pin for pin compatible.
I think you will need to make the appropriate wiring changes depending on what ECU and Harness you are trying to use.
Look at this post on the VW Vortex
VWVortex.com - APH, AWW, AWP, AWV wiring harness comparison
K
Old 11-17-2012, 01:43 AM
Kula191
Thx!! Link def w/def be helpful!!!
So far I went with the ECU from the 99 AHP, the 2000 AWP is in a box. We adapted a couple connections already because certain harnesses changed from 99 to 2000. I have 2 i believe.. connections in the wiring that seem not to have a corresponding harnesses on the newer motor/Trans or close by sensors on various parts.
That being said... is it possible to consider a full pump cut-off switch in this car? If so.. and it needs reset? Where is it located?> Could be a possible resolution?>
LMK your thoughts
Engine Swap (AWV to AGU) docleo 1.8 Liter Turbo 3 10-16-2012 07:48 AM
DIY Engine Swap DevilsWorkshop Engine Swaps 4 06-29-2011 02:13 PM
Console Swap Issues sanlyn Styling Modifications 5 05-16-2011 12:10 AM
2.0 to 2.0 engine swap ibeem2k 2.0 Liter Gas 5 02-06-2011 08:47 PM
2001 glx + awp engine swap = check engine light!?! NEED HELP garvitron 1.8 Liter Turbo 7 05-07-2009 12:22 PM
