Coolant ? - NewBeetle.org Forums
Old 12-01-2012, 10:42 PM
fastdustin's Avatar
NY, USA
Car: 2001 VW New Beetle Sport
Default Coolant ?
I recently was under my hood and changed the coolant temp sensor. While I had it off I noticed my coolant was orange and the reservoir had orange coolant in it. I just had the timing belt and water pump done at vw a few a little while back. Isn't g12 coolant pinkish or the new g12+ is a new color right??
Old 12-01-2012, 11:21 PM
Fairfax, VA, USA
I recently purchased a gallon of G12 from the dealer, not sure what G12+ is??, but my G12 is pink in color.
Orange may be DexCool???
Old 12-01-2012, 11:38 PM
G12+ is the new stuff. I think its purple vs the pink of g12 but they should all be compatible.
Sent from my SCH-I405 using AutoGuide.Com Free App
Old 12-02-2012, 04:31 AM
Knoxville, TN,
G12+ can be mixed with G12. It is my understanding the G12+ is mainly from Audi to address heater core issues (the B5 Passats also have the same problem). Those heater cores get clogged up with "sand", mineral deposits or whatever. Beetles don't have this issue, so there unless G12+ is cheaper, there is no need to use it.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 12-02-2012, 02:46 PM
edu01jose's Avatar
Some dealers use Dexcool Prestone coolant I believe which is orange. At least that is what I use on mine since it's cheaper and compatible.
Old 12-02-2012, 03:00 PM
VW dealers do?
I would never use anything other than G12/G12+/G12++ unless I did a very, very thorough flush. I don't care if it says its compatible, I wouldn't risk clogging up my cooling system. G12 isn't all that expensive, and unless you have a leak, you shouldn't really need to use it all that often anyway.
Old 12-02-2012, 03:07 PM
IndyTom's Avatar
Indianapolis, IN, USA
Who told you that Dexcool is compatible? That is so not True.
And I can't believe a dealer actually would be using such a product since they would open themselves up to a potential lawsuit not only from the consumer but from VW USA for not using the proper VW approved product.
So I seriously doubt that this dealer is using DexCool
Old 12-02-2012, 05:11 PM
CGK's Avatar
CGKNewBeetle.org Member Sponsor CGK is online now
Beetleman
Salisbury, NC, USA
The main issue with coolants is that VW's MUST use a phosphate free coolant. It's the phosphate that causes corrosion similar to electrolysis that reacts with the two different metals, aluminum in the head and cast iron in the block.
So, unless the coolant specifically states that it is phosphate free do not use it.
Play it safe, use only VW approved coolant either OEM Pentosin or Autobahn coolant. Both can be found online or at the dealer.
And, to restate what everyone has said here, G12,G12+ and G12++ are all interchangeable and mixable with each other. DO NOT under any circumstances mix G12 with G11(blue) coolant.
That is all.
Old 12-02-2012, 11:17 PM
fastdustin's Avatar
NY, USA
so i went and pulled the service file for my vw and it clearly states installed G012A8G1G coolant. i looked up this part # and it says g12 coolant which should be pink but mine is clearly orange. suggestions on what to do here. I mean i clearly paid to have my timing/water pump service done and it was at an official vw dealer. The owner also has a chevy dealer so maybe they put in something else like dex-cool. ive been running this coolant since 8/2/12 and nothing has gone wrong.
Old 12-03-2012, 12:18 AM
I've seen g12 appear more orange once dilluted.
Old 12-03-2012, 12:23 AM
fastdustin's Avatar
NY, USA
thanks for the help i guess im safe then. sorry for all the trouble. At least i learned a little about the coolant for my car
Old 12-03-2012, 12:33 AM
IndyTom's Avatar
Ardeca Lubricants ALU Freeze G12+ Life Long Anti Freeze Coolant Concentrate,View anti freeze coolant,Ardeca Lubricants Product Details from VROMAN NV on Alibaba.com
Here is some G12 that looks pretty orange to me.
Here are some images from Google that should put your mind at ease:
https://www.google.com/search?hl=en&...OOvxyAHk04CIBg
Coolant temp indicator/coolant temp sensor terror_storm 1.8 Liter Turbo 2 11-07-2010 04:05 AM
g12 coolant ? Wombat99VW New Member Forum 1 10-11-2009 03:13 AM
Oil in coolant... ldefoggi 2.0 Liter Gas 9 09-18-2009 02:04 PM
G12 coolant mix mulligania 1.8 Liter Turbo 6 06-13-2008 01:15 AM
Coolant Leak - D/S - Coolant Flange Scarab 1 Questions, Issues, Concerns, or Problems with the New Beetle 17 06-28-2007 12:16 PM
