Traction control & ABS light - NewBeetle.org Forums
Old 12-07-2012, 03:37 AM
Question Traction control & ABS light
Could these be sensors? How can this be fixed? Where are these two sensors located? Would i be able to fix it myself or should it be taken to the auto repair shop and done by a technician?
Thanks
Old 12-07-2012, 03:49 AM
bme's Avatar
bmeNewBeetle.org Member Sponsor bme is offline
Goodyear, AZ, AZ, USA
Car: 2003 Turbo S
Thanks
You can't know until you check the codes in the control module that help indicate what the problem actually might be.
Sent from my iPhone using AutoGuide.com App
Old 12-07-2012, 04:05 AM
I did scanned and it came out for the air pump but nothing or the other too ones
Old 12-07-2012, 01:16 PM
You'll need VAG-COM to read the codes in the ABS module. Codes for that won't show up with a generic OBDII scanner.
Old 12-07-2012, 02:48 PM
Ohhh i c
Old 12-07-2012, 02:52 PM
Default Gain Muscle Mass With Overall Health Benefits
If you wish to enhance your lean body mass and look like a hunk then you definitely require nitric oxide pills to help you achieve this. So what are you waiting for? Bring Muscle Factor X home and get a muscular body now!
Abs and traction control light on Winterbeetle 1.8 Liter Turbo 6 08-21-2010 03:55 AM
ABS & Traction Control Light coming on... Bert336 1.8 Liter Turbo 1 06-15-2010 03:42 AM
Traction control and ABS light ph34r Questions, Issues, Concerns, or Problems with the New Beetle 4 04-05-2010 10:06 PM
ABS traction control light on.. fohveh Questions, Issues, Concerns, or Problems with the New Beetle 7 06-02-2009 10:24 PM
EPC and traction control light come on?? mat3833 1.8 Liter Turbo 12 03-13-2009 01:12 AM
