Clutch appears to work but car doesn't move. - NewBeetle.org Forums
Old 01-17-2013, 02:35 AM
blue scarab's Avatar
Little Falls, MN, USA
Car: 2001 GLX
Default Clutch appears to work but car doesn't move.
I was pulled into my driveway too slowly and killed the engine in 3rd gear. I restarted the engine, released the clutch and all I hear is a high speed grinding noise. I tried other gears with the same results. I pushed Blue into the garage. Any ideas?
Old 01-17-2013, 12:25 PM
Fairfax, VA, USA
Possible broken shift fork??
VWVortex.com - Have you broken a shift fork? (Poll)
Old 01-17-2013, 01:31 PM
Shift fork problems are only an issue on the 6-speed manuals, AFAIK. I've not heard of it on a 5-speed. And the Turbo S is the only NB with the 6-speed.
Old 01-17-2013, 04:40 PM
Car: 2001 GLX
Blue is going into the shop next week. I'll let you what happened.
Here's what happened. The splines in the clutch plate stripped out.
New dual mass clutch/pressure plate cost just under $1000. Add another $400 for labor.
Last edited by blue scarab; 03-09-2013 at 01:33 AM.. Reason: To tell about outcome.
2010 Beetle, Gear Sporatically Appears on Dash sunshinedi Questions, Issues, Concerns, or Problems with the New Beetle 2 10-09-2010 01:55 PM
My Bug won't move! jeremyrwilcox Transmission Talk 0 09-27-2009 02:40 PM
vagcom gurus - won't test - all appears connected my99vdub Questions, Issues, Concerns, or Problems with the New Beetle 21 07-30-2008 06:15 PM
Where should I move? MattP Miscellaneous Hoo-Ha Archive 25 03-07-2006 11:49 AM
