Blue coolant light flashing? - NewBeetle.org Forums
Old 04-12-2006, 05:30 PM
DruzeTito's Avatar
SK 436 EN
Sarasota, FL,
Car: Pontiac G8 GT
Default Blue coolant light flashing?
Hey everyone..
A few days ago I was driving my 1.8T Y2K Bug and suddenly I saw the blue coolant light temp flashing for maybe a minute then it turned off. What does this mean? I saw my coolant level and it's good.
Also sometimes I drive and the engine is well warmed up but sometimes the blue light will come on steady for no reason and then maybe turn off within 5 mins.
Doesn't seem like a huge problem but I would just like to know if it's something serious or not.. thx.
Old 04-12-2006, 05:54 PM
awetsock's Avatar
Arlington, TX, USA
Car: Red 2003 Turbo S
If it comes on blue after the engine is well warmed up, it could possibly be a bad temp sensor. Around $6 for a new sensor.
Old 04-12-2006, 07:16 PM
Breez's Avatar
Life is good.
Phoenix, Arizona, USA
Car: "BB" a 2001.5 New Beetle 2.0L GLS in Techno Blue
If it is only solid blue when you are first driving the car, thats fine.
Flashing or Red is not good and needs to be looked at (at least thats what my manual said)
hope that helps
Old 04-12-2006, 08:00 PM
DruzeTito's Avatar
SK 436 EN
Sarasota, FL,
Car: Pontiac G8 GT
hope that helps
Yes, when i first drive it's solid blue so I know that that's normal. But then after a while it comes on again and turns off. But i only saw it flash about two times for about 1 minute and stop.
I looked at the manual as well and it said it might be an electrical problem? I dunno. Maybe it is a bad temp sensor.
Old 04-14-2006, 02:12 AM
speedie's Avatar
Eine Kleine Panzer
Lampasas, TX, USA
Car: 1968 Bug 2001 New Beetle 1.8T 2003 New Beetle 2.0
Do a search for green temperature sensor and you will find buchu posts telling you how to fix it. Check your coolant level too...if it is not too low you can add some distilled water to it.
Old 04-14-2006, 01:49 PM
CyberGypsy's Avatar
Car Crazy Girl
Ocala, FL, USA
Car: 2001 GLS Turbo Vortex Blue
LOL ......
Days get shorter
weeks go by
growing old
in the blink of an eye
Old 04-18-2006, 11:54 PM
watermanjudy's Avatar
Default Temperature Light Flashing
Did you solve your problem with the blue temperature light flashing? I am having the same problem with the red temperature light. It goes on for about a minute and then goes off. The dealership can not find a problem and of course, it doesn't flash for them. It sounds like a sensor problem but don't really know. The instrument cluster was changed two days after I took delivery, as the car wouldn't start (not recognizing the key) and had to be towed.
Old 04-19-2006, 12:12 AM
dvious's Avatar
triple dubness
TX,
Have you checked your coolant level?
Blue coolant light comes on? ChuckDubDub 1.9 Liter TDI 22 05-17-2012 03:16 AM
Brake Warning light flashing. wabanaki Questions, Issues, Concerns, or Problems with the New Beetle 5 02-29-2012 01:21 PM
Why Is My Engine Immobilizer Light Flashing? Bugdoo Questions, Issues, Concerns, or Problems with the New Beetle 4 07-02-2006 11:25 PM
Flashing blue temp light Shamrockez Questions, Issues, Concerns, or Problems with the New Beetle 2 12-21-2005 04:57 PM
