Oil Leak - From valve cover?? - NewBeetle.org Forums
Old 04-19-2006, 01:53 AM
VW Crazy
Golden, CO, USA
Car: 2000 1.8T
Default Oil Leak - From valve cover??
Hi Folks,
On our 2000 NB 1.8T, we are getting an oil leak from the valve cover gasket. It is coming on the back driver side of the head, where the half moon is cut into the head. We put a new valve cover gasket on with no fix. Took it off and put some sealant just around the half moon portion of the gasket - still leaking.
I am wondering if there is an issue with the ventilation? I pulled the hose off of the valve cover and blew and sucked air through it - no problem there. I checked the PCV equivalvent that goes to the intake boot, breates easily in both directions - that seems odd?? Likely bad - I thought it should only go in one direction - into the boot.
Has anyone else experienced this and if so how did you fix it. Looking at the engine, it looks like this leak has been there for a long time. We recently purchased it.
Thanx for your insight!
Z
Old 04-21-2006, 03:42 AM
nyum96's Avatar
HotLanta, GA, USA
Car: 01 Beetle 1.8T APH
Same here. I believe there is a "seal" that goes around the two camshafts in that area. Thats the only reason why it would leak, if not the valve cover.
Old 04-21-2006, 05:08 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
With the motor running, carefully remove the oil filler cap. Is a lot of air/vapor escaping?
The PVC system is made up of a series of hoses, check valves, and connectors. Why VW couldn't just use a cheap PCV valve is something only for the German mind to comprehend.
Old 04-24-2006, 03:52 AM
VW Crazy
Golden, CO, USA
Car: 2000 1.8T
I did a test of the breather system. Air is blowing out of the valve cover when I remove the hose. I then followed the lines all the way to the valve on the intake boot. Everything seemed okay there. Only problem I found was that the valve is not working correctly. Its locked in a partially open position. Picking up a new one tomorrow. I believe this is causing pressure to biuld up in the head and then the oil abd pressure have to get out somewhere.
Z
98 2.0L leaking oil from valve cover...... cupacof 2.0 Liter Gas 2 11-12-2007 02:18 AM
Oil Leak????? Jarhead96 1.9 Liter TDI 6 03-29-2006 11:29 AM
combie valve & N112 valve (vacuum lines)??? marisagi 1.8 Liter Turbo 1 02-09-2006 11:53 AM
2001 NB With a bad oil leak! McYoda 1.8 Liter Turbo 1 01-19-2006 09:53 AM
antifreeze leak rob11g Questions, Issues, Concerns, or Problems with the New Beetle 4 11-01-2005 04:01 PM
