Question: How to change fuel filter - NewBeetle.org Forums
Old 04-19-2006, 03:15 AM
Default Question: How to change fuel filter
Hi all:
I'm a newbie and just got a 2000 1.8T Beetle. I want to change the fuel filter and have the filter from VW. I got the fuel filter off the rail but was not able to disconnect the plastic fuel lines. Is there a trick? Do I need a tool?
Can someone help? I tried search but didn't find what I was looking for.
Thanks a million.
1pt8t
Old 04-19-2006, 04:15 AM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
Pull really hard. It does come off. Be prepared to be sprayed. It's a tight space, my friend got it off with his hands and/or pliars. It clips onto the lump on either side of the stems on the filter itself.
Phoenix: 2003 Uni-Red New Beetle GLS TDI 132k former-automatic with a 1998 TDI Manual Transmission swap.
Old 04-19-2006, 04:19 AM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
Ummmm. I wouldn't pull too hard, the lines are plastic and tend to get brittle...The clamps that hold the filter on are squeeze clamps, use vice grips and light to moderate pressure to release the clamp, then slide the line off...Get ready to stink like gas too...
(\__/)
(")_(")
Me: www.myspace.com/beetlenut
Old 04-19-2006, 05:26 AM
thanks guys! after scouring the net more, i finally found a picture of a guy doing a Jetta fuel filter. As it turns out, there is a button you push on the end of the connector.
Once i figured that out, the install from start to end took 15 minutes.
thanks again.
1pt8t
Old 04-28-2006, 10:17 PM
Taters Toy's Avatar
FunSize
Kyle, TX, USA
Car: 2001 Black 1.8T Sport
Question Another Filter Question?
Anyone know where its located? I have ordered a repair manual because the part store in town doesn't have a manual for my NB. I want to do this right away if possible.
Ever notice how anyone going slower than you is an idoit , and anyone going faster than you is a maniac!
Big Tater
See Taters Toy
Old 04-28-2006, 10:22 PM
paultakeda's Avatar
Bourgeoisie
Venice, CA, USA
Car: 2001.5 NB GLX AWV 02J LG5T 08H/ZD + mods
Follow the fuel line back towards the tank, it's near the tank. This writeup is for a VR6 Jetta but you get the idea.
Old 04-29-2006, 01:19 AM
On the Passenger side, right in front of the back tire. (look up from there)
1pt8t
Old 05-07-2006, 06:04 AM
IgottaBug!'s Avatar
Thomas
Joliet, IL, USA
Car: 2000 1.8t GLS
Changed mine tonight and it was a PITA! I read a how to on the old forums and thought that I could get it done in at least 30 minutes, but my big hands cramp up in tight places. Now I know why I didn't become a mechanic!
When you can't beat em', join em'. Then take em' apart from the inside.
Old 05-28-2006, 06:46 PM
Taters Toy's Avatar
FunSize
Kyle, TX, USA
Just a quick note to anyone who is changing thier fuel filter. This link is SUPERB!!!! The biggest key is to be sure and press the clips on the line where it connects to the fuel filter. I didn't on the first one, but the second one just slipped right off with a little tug. Follow the instructions just as described and you can literally have it changed in about 20-30 minutes...including prep time.
Old 06-06-2006, 09:25 AM
mezonesxbox's Avatar
Beetle maniac
Newport Beach, CA, USA
Car: New Beetle 2000 GLS, Audi A6 2000
Do you need to have the tank totally empty or does the car have a fuel regulator and all the fuel that is sprayed is just remainders from the fuel lines and not the tank draining itself empty?
Old 06-06-2006, 03:31 PM
You don't need the tank to be empty, it is just the remainder from the line. Good luck!
1pt8t
Old 06-06-2006, 03:51 PM
Anaconda's Avatar
formerly known as BROWN E
Austin, TX, USA
Car: 2001 NB 1.8t
What's the recommended mileage to replace the fuel filter?
http://www.myspace.com/4603066
Fuel Filter iScott 2.0 Liter Gas 4 04-26-2006 03:25 PM
Changing Fuel Filter Oyveychris 1.8 Liter Turbo 3 01-21-2006 09:47 PM
Fuel Filter Replacement funky 1.8 Liter Turbo 13 01-02-2006 08:35 PM
New Beetle Fuel Filter Replace (2003) fglass 2.0 Liter Gas 3 10-29-2005 04:33 AM
Problems changing plug wires & fuel filter. jent 2.0 Liter Gas 8 10-10-2005 09:04 PM
