I have the following DTCs:
17832 P1424 Sec.Air Inj.Sys.,Bank1 Leak Detected 17584 P1176 O2 Correction Behind Catalyst,B1 Limit Attained 16804 P042 (intermittent)Catalyst System,Bank1 Efficiency Below Threshold I know the exhaust codes have to do with my O2 sensors and high flow cat, so I'm not worried about them, but I am getting some hesitation after initial spool-up that I associate with the 17832 code. Any ideas one what potentially faulty parts are associated with 17832? I'm leaning toward my J valve or MAF.. Also, my mileage is just terrible and has been for about 6 months. |
The (SAIP) Secondary Air Injection Pump is a black plastic unit which is normally located below the intake manifold toward the left (driver side) of the cylinder head, the Combi Valve (which can also fail) is on the same side but further back toward the firewall at the end of the cylinder head.
The SAIP and Combi Valve are connected via one of the two black plastic hoses while the second plastic hose goes from the SAIP to the airbox, these hose can leak and cause problems as well, the SAIP is what you hear running/whining for a minute or so when you first start your car in the morning. This is an emissions device that injects oxygen into the exhaust system on first starts in order to insite a cleaner burn. |
| Secondary Air Pump....... Interchangeable? | nyum96 | 1.8 Liter Turbo | 1 | 04-20-2006 11:30 PM |
| Secondary Air Pump Hose | 2000GLX | 1.8 Liter Turbo | 4 | 02-23-2006 01:37 PM |
| secondary air pump. yay. | mr_punch | 2.0 Liter Gas | 0 | 11-26-2005 11:53 PM |
| missing secondary air hose | jazzcat | 2.0 Liter Gas | 2 | 11-16-2005 05:38 PM |
| Secondary Air Pump and other questions | mon11 | 1.8 Liter Turbo | 5 | 10-18-2005 03:41 AM |
