How do I change the comi valve on the secondary air injection. - NewBeetle.org Forums
Old 06-10-2006, 03:42 PM
scoester's Avatar
Finally got a new Beetle!
Nampa, ID, USA
Car: '99 Silver GLX
Unhappy How do I change the comi valve on the secondary air injection.
I looked in the manual all it says is unhook the air tubes and "remove" valve. Do I have to do this from under the car? what tools do I need?
Beetle APH 1.8T
Thanks
Old 06-10-2006, 09:37 PM
jackfrost's Avatar
and your little dog too!!
Gurnee, IL, USA
Car: 2000 Cool White glx
the combi valve is up top close to the firewall, not hard to swap out, its black like this
Old 06-11-2006, 03:50 AM
dumb question, but is that the same as the diverter?
Old 06-11-2006, 04:38 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
No, different devices.
While you have things apart, consider replacing the vacuum lines too.
Old 06-11-2006, 04:53 AM
scoester's Avatar
Nampa, ID, USA
Car: '99 Silver GLX
That photo is the diverter valve. It is located on the intake pipe. The Comi valve is part of the emission system the secondary air injection to be exact. It is bolted to the head with three 5mm hex head bolts. Kind of PITA to get at, but got her done. Already did the Vac lines. I am hoping that I have narrowed the CEL down to this.
Thanks
Old 06-11-2006, 09:07 AM
SoCal, Pacific Ocean
Thanks
Just curious... how did you know the Combi Valve was failing? Is there a procedure to test it?
Old 06-12-2006, 05:26 AM
does anyone have a picture of the valve? i keep getting a p1421 and i have replaced every vacuum line and new diverter. i think i need to replace the valve.
Old 06-12-2006, 05:44 PM
jackfrost's Avatar
Gurnee, IL, USA
oops my bad, guess i should have read the question. the combi valve looks like this
follow the hoses from the air pump you will run right into it.
Old 06-12-2006, 06:43 PM
scoester's Avatar
Nampa, ID, USA
Car: '99 Silver GLX
Through a slow process of elimination, (only slow because I could only carve out a few minutes here a few there to check things.)
Started with getting the CEL.
Checked the Vac lines, They literally turned to dust in my hands.
Replaced the Vac lines. Gave it a few days to see if that helped.
Got the CEL again.
Checked the vac solenoid it is providing vac to the comi valve.
Pulled vac line from combi valve and applied vac to valve, could not get it to work. However I must of done some good, because my code went from just saying incorrect flow detected all the time to being intermittent
Ordered and changed the combi valve. Not difficult, but a tight fit with the coolant line right in front of it.
Waiting to see if CEL returns. Keep your fingers crossed.
Old 06-12-2006, 08:49 PM
jackfrost's Avatar
Gurnee, IL, USA
heres hopin dude ::fingers crossed::
Code help - 17832 Secondary Air Injection bolwin1 1.8 Liter Turbo 4 05-01-2006 03:20 AM
Secondary Air Pump....... Interchangeable? nyum96 1.8 Liter Turbo 1 04-20-2006 11:30 PM
Secondary Air Pump Hose 2000GLX 1.8 Liter Turbo 4 02-23-2006 01:37 PM
missing secondary air hose jazzcat 2.0 Liter Gas 2 11-16-2005 05:38 PM
Secondary Air Pump and other questions mon11 1.8 Liter Turbo 5 10-18-2005 03:41 AM
