Engine takes a few too many turns to start.... - NewBeetle.org Forums
Old 11-26-2006, 07:50 PM
Shamrockez's Avatar
M16S VW & VW53HRB
Somerset, UK, England, United Kingdom
Car: 1998 TDi Texan import- 'Robbie' & 2008 Herbie Driving School Beetle
Default Engine takes a few too many turns to start....
It's not a problem as such, but something which annoys me on my Beetle.
He's a 98 ALH TDi (non PD), and when I start him he turns over a fair few times before he fires up. He never fails to start, so as I said, it's not exactly a problem.... but it's a bit embarrasing sometimes when he takes (what seems like) ages to start.
He starts better when it's cold - pretty much as soon as you turn the key. The colder the weather the better he starts it seems. But when he's been used, then restarted he takes a good 5 seconds to fire up.
Anyone know what the cause of this is? Is it the glow plugs?
Thanks
Lucy.
1998 1.9TDi, Texan Import. Cup car body kit, RSI alloys and air.
Evvo - UK New Beetle Club
Old 11-27-2006, 02:54 AM
Bend, OR, USA
Car: 2004 Jetta TDI and 1998 NB
Check out this thread on TDIClub.
Lots of information and troubleshooting. Start by getting the car hot then unplugging the coolant temperature sensor. If it starts faster, you know that your problem is the same as everyone else with the early A4s.
TDI No start troubleshooting.
Old 11-28-2006, 04:53 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
Something to check. Have the pump timing checked. If it is not above the line, it will be difficult to start.
Old 11-29-2006, 01:03 AM
-1-'s Avatar
-1-Registered Member -1- is offline
All-American
Chester, VA, USA
Car: '06 NewBeetle TDI "Prius Eater"
I had a 1999 NewBeetle TDI (March 99 - May 06). It was difficult to start after the first several years. Had it checked, new parts, nothing helped. Finally traded it for a 2006 Beetle TDI.
......................-1-.......................
.............Prius Eater............
.'06 NewBeetle TDI .
My other car is a 2006 NewBeetle TDI
2006 NewBeetle Prius Eater
Old 11-29-2006, 01:37 AM
Bend, OR, USA
What parts were new?
Old 11-29-2006, 08:04 PM
Jackson, TN,
Car: 2000 NB GLS TDI, '06Jetta TDI
YOu probably just need a new battery. Diesels have a ton of compression and just a mildly weak battery will cause this.
'00 NB TDI GLS 5 speed
'05 Passat TDI.........totaled
'06 Jetta TDI package 2 with DSG
Old 11-30-2006, 03:45 AM
Knoxville, TN,
I second that! And just because a battery passes a battery test doesn't mean that isn't the cause of long cranking times on a TDI. Said battery might be "gasser good" but shy of getting that TDI crank up to speed.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 12-01-2006, 12:03 AM
-1-'s Avatar
All-American
Chester, VA, USA
Last part purchased was a new 2006 NewBeetle TDI. Specifically, new glow plugs X2, glow plug wiring harness, sensors, mass flow air sensor. Not sure of what else. Had it checked several times, never got any better. New 2006 starts TOO easy.
Old 12-01-2006, 03:33 AM
Bend, OR, USA
Regarding the battery:
Therefore, not likely. Certainly get it checked to be sure though.
Did you try disconnecting the temp sensor before you start it when it's warm?
Old 02-13-2007, 07:51 PM
mandujano1's Avatar
Spring
Rockford, IL, USA
Car: 2001 VW New Beetle GLS Sport
Default Starts Take Longer 99 TDI
My Daughters car started doing that and i checked the battery and it was ok. I replaced the Bosch starter with a Bosch rebuilt one and it made the cranking time less.
rdsvw2@aol.com
Old 02-15-2007, 09:08 PM
Pittsburgh, PA,
Car: 2002 NB TDI White 5-speed
If it starts better when the engine is cold, then it doesn't sound like the injection timing or the quality of the diesel fuel.
Look at the thread posted above, and have the coolant temp sensor checked.
Bean juice on the tank!
What is biodiesel? www.biodiesel.org, http://www.eere.energy.gov/afdc/altfuel/biodiesel.html
Where can I get some? http://forums.biodieselnow.com/
Old 02-15-2007, 10:57 PM
Hampton, VA,
Car: Big/Bad Diesel Suburban
Try replacing the factory battery to starter cable.
Have the battery tested, don't just run out and buy one.
I replaced the 4ga cable that some dumb person put in my truck with an 00 gauge cable. The old under sized cable was starting to burn up and degrade. Making my truck crank real slow.
Now with the 00 gauge cable it cranks like the '05 power stroke diesels I have where I work.
1984 6.2L diesel Suburban
1985 Z28 Camaro
http://www.cardomain.com/id/oil_pan_4
Old 02-16-2007, 12:47 AM
JetPuf's Avatar
Wee more cowbell
Troutdale, OR, USA
Car: '98 GLS TDI 5sp
A buddy of mine over on TDI club had a similar problem in his 99.5 jetta TDI. the fix he had was a new starter. the old one wouldent spin fast enough. Worked will when the car was cold because of all the cold start help that the pump gives it, but took some cranking when the car was warm. Look him up on tdi club, Nicklockard.
White '98 NB TDI "JetPuf" 233k
All the fixins'
Old 02-27-2007, 09:48 PM
Shamrockez's Avatar
M16S VW & VW53HRB
Sorry I didn't get the replies to this. He's had a new battery and I've replaced both coolant sensors - none of which made any difference.
I'll try the other ideas
Ta
Old 02-28-2007, 05:28 PM
jpdeuce's Avatar
Diesel Inside
Frisco, TX, USA
Car: 06 Jetta TDI
I've also heard that its not as big of a deal for the TDI not to start instantly. It's ok if it takes a couple turn overs to get going. Mine slows down some in the cold weather. But I tested the glow plugs and they are fine. I wouldn't worry too much about it unless you aren't getting it to start at all.
Old 02-28-2007, 06:25 PM
JetPuf's Avatar
Wee more cowbell
Troutdale, OR, USA
A TDI shold start just like any other car. VW spent alot of engineering time so you can drive and operate the car just like any other car, it does not need to be driven special or anything.
However that being said like I posted earlier, it could be the starter. to get a good start the engine needs to be spun at atleast 400rpm.
Old 03-07-2007, 08:26 AM
Shamrockez's Avatar
M16S VW & VW53HRB
I unplugged the sensor (I think I did the right one? I removed the one in the coolant tank and the one which goes to the sensor in the pipe under the engine cover.) and it didn't many any difference at all.
Old 03-07-2007, 10:34 AM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
This makes sense, most big diesels use 24 volt starting.
Old 03-08-2007, 12:55 AM
Bend, OR, USA
The one in the coolant tank is the wrong but and I think the other one is the wrong one as well. Was it between the engine and the radiator, or was it between the engine and the firewall in a block attached directly to the back of the engine?
Old 03-08-2007, 09:00 AM
Shamrockez's Avatar
M16S VW & VW53HRB
Really? Does anyone have a pic of which wire to remove?
Engine turns off Paradoxx 2.0 Liter Gas 4 11-23-2006 07:53 PM
2000 NB 1.8T - Engine randomly turns off mooosenix Questions, Issues, Concerns, or Problems with the New Beetle 7 08-12-2006 07:53 PM
**** Noise from engine at start-up ***** big3.mango Questions, Issues, Concerns, or Problems with the New Beetle 12 08-03-2006 01:39 AM
it takes more than one try to start my beetle liquid_cocaine 2.0 Liter Gas 0 07-10-2006 07:38 PM
When you first start your engine . . . . EvilinaDM101 2.0 Liter Gas 21 04-12-2006 08:57 PM
