airbox cover bolts - NewBeetle.org Forums
Old 02-28-2007, 08:21 PM
basskleff's Avatar
Question airbox cover bolts
Hi Bug owners,
Have any of you got an alternative fastener for putting the airbox cover back on? What I've found is that the 2 philips head bolts are in such an awkward spot that the heads like to strip. I have one that I definitely need to replace.
I've changed the airfilter twice, and I almost could not get the cover off due to that bolt. I wished they had employed speed clips like every other car manufacturer.
If no alternative, does anyone know of an after market place to buy them?
The one dealer I spoke with this morning, said the bolt wasn't sold separately.
I'm going to try some more dealers and then some of the preferred vendors.
Old 02-28-2007, 10:04 PM
jpdeuce's Avatar
Diesel Inside
Frisco, TX, USA
Car: 06 Jetta TDI
I think the same thing every time I replace mine. I'm just glad its not more often than 20K miles.
Old 02-28-2007, 10:12 PM
noR's Avatar
Administrator
Jackson, MS, USA
Good luck. I don't think you'll have much chance out there.
But any clamp should work.
The screws; I just don't torque down very tight; and I don't remove them. They're in there in such a way you just have to loosen them and they're off; don't have to physically remove the screw from the lid.
noR | me | Phrog
PHROG
Old 03-25-2007, 05:31 AM
You can go to just about any hardware store and find replacements for the screws... But they will be threaded all the way to the top... If you pull the upper cover assembly (sorry, I dont know what its called) that the wipers go thru, you can get at those screws much more easily...
Drag
Think my bolts are stripped - intake cover. IgottaBug! 1.8 Liter Turbo 0 05-07-2006 07:33 PM
Stretch bolts... reuse them? BozemanboB 2.0 Liter Gas 4 04-02-2006 04:31 PM
Stretch Bolts Ouphe 2.0 Liter Gas 8 01-20-2006 12:05 PM
4-6mm allen bolts on bottom pulley sequoiagrapeboy 2.0 Liter Gas 6 10-27-2005 11:58 PM
WANTED!: 2.0 Airbox E-AT_me Market Place Archives 2 09-27-2005 04:31 PM
