TDI mechanic in Ga, Savannah area - NewBeetle.org Forums
Old 03-01-2007, 03:56 AM
fuforums's Avatar
Beetle Person
Savannah, GA, USA
Car: 2001 New Beetle Tdi GLS, 2004 New Beetle GLS Tdi DSG 6spd
Default TDI mechanic in Ga, Savannah area
I need a belt change. Mechanic wants to charge 800 using MY parts for a belt change, water pump change, and oil change. I think that's too high. Haven't even called the dealer but I'm sure it's worse.
Anyone know of a mechanic near the Savannah area or the Jacksonville area or Charleston, SC area? I want to get this done before I start my WVO conversion.
Help would be appreciated.
Joe
2004 New Beetle Tdi GLS DSG 6Spd
Savannah, Ga
Old 03-01-2007, 04:02 AM
iScott's Avatar
Die with your boots on
Atlanta, GA, USA
Car: Noir'a, black '98 2.0
Not fimiliar with that area, but you can always check out kudzu.com or just plain call around. Check VWVortex.com, too. $800 is WAY too high. Especially if you have the part. Don't get ripped, friend. Good luck!
Floored
Old 03-01-2007, 06:31 PM
QQQ's Avatar
QQQRegistered Member QQQ is offline
Fairfax, VA, USA
Car: Y2K GLS TDI
I live in the Wash DC area and went to tdiracing to have it done for $300. I'm happy with the results. Looking here, this person seems recommended:
http://forums.tdiclub.com/showthread.php?t=168373
Goodluck.
Old 03-03-2007, 01:09 PM
Youngsville, NC, USA
Car: 2000 GLS TDI Automatic
Goodluck.
Get over to www.tdiclub.com and start looking for Gurus reasonably close to you. You do not want someone not very familar with TDI's doing this critical procedure (we're talking about the difference between a car running for 500,000 miles or blowing up in the next month after it's done). If the mechanic says he just does "mark and pray" - RUN ! You absolutely MUST have the proper lockdown tools and a computer to properly set the timing.
2000 RED TDI New Beetle, 4 speed automatic...
Old 03-08-2007, 01:29 PM
LPCRegistered Member LPC is offline
GA, USA
Car: 1998 TDI NB
This is the thread.
http://forums.tdiclub.com/showthread.php?t=130044
In GA Atlanta Roger Feldt at 678-907-4221
Needed: Pittsburgh Area VW Mechanic ebt12 2.0 Liter Gas 3 12-15-2006 09:59 PM
Savannah and the Ring – The Story of my Engagement Freaky Beetle Miscellaneous Hoo-Ha Archive 13 09-22-2006 06:06 AM
I need timing belt mechanic st louis area 2002 1.9 tdi tomismyname 1.9 Liter TDI 3 09-05-2006 08:47 PM
Anyone knows a good VW mechanic in the Bay area? ptmlinh Questions, Issues, Concerns, or Problems with the New Beetle 4 08-09-2006 02:38 PM
Seattle Area VW mechanic Vivan Market Place Archives 3 06-27-2006 12:39 AM
