Best place to jack New Beetle up for Jack Points - NewBeetle.org Forums
Old 06-25-2007, 04:31 PM
amishman's Avatar
CA, USA
Car: 2001 TDI Beetle
Default Best place to jack New Beetle up for Jack Points
I want to use my better floor jack to swap tires rather than the little flimsy emergency jack provided by VW. Where is the safest and best place to place the jack under so I can jack up the New Beetle and swap tires?
Thanks
tj
Old 06-25-2007, 04:54 PM
dnyed's Avatar
Thankless Mod Queen
Vancouver, via Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
There are dimples on the running board. These are the jack up points.
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
Old 06-25-2007, 05:52 PM
Wheaton, IL,
Car: 04 TDI PD
Careful - you could damage the pinch weld if you use a floor jack on the dimple locations. IIRC there's already a thread for alternate jack points.
Old 06-25-2007, 05:57 PM
noR's Avatar
Administrator
Jackson, MS, USA
Not the running boards. Those are alot softer than they look.
The dimples show the front-to-rear location, but the jack point is about 6-8" inside of that.
There's some grommet holes that I use, and realy I've been wandering around as my 'jack points' are started to get well chewed over time.
Sorry, I don't have a pic. But I'd say aim for 'just around' the sizable grommet locations, indicated by the dimples.
noR | me | Phrog
PHROG
Old 06-25-2007, 06:03 PM
dnyed's Avatar
Thankless Mod Queen
I guess I should have elaborated. I know that the jack points are farther under the car, back from those dimples. Sorry....
Old 06-25-2007, 06:23 PM
noR's Avatar
Administrator
Jackson, MS, USA
S'all good, I just had a bad experience lifting AT the dimples; don't wanna wish that on anybuddy. (I REALLY shoulda known better at the time.. but it was completely my fault anyway.)
Old 06-25-2007, 06:41 PM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
I usually put a 2x6 around 3 ft long just inside the weld and use the floor jack to lift the front and rear at the same time.
Old 06-25-2007, 11:40 PM
vdubbugman53's Avatar
Arvada, CO, USA
im lowered so i have to drive up on 2x4s but then u just use the Sub Frame then u put jack stands under the sub frame too
Old 06-26-2007, 04:18 AM
Bend, OR, USA
Car: 2004 Jetta TDI and 1998 NB
I just bench press mine up, then with one hand hold the car and with the other hand slide jack stands underneath.
Jacks are for wimps.
TDI No start troubleshooting.
Old 06-26-2007, 07:01 AM
FarrisK's Avatar
Semi-Lurk Mode: GOOOOO
West Richland, WA, USA
Car: 2004 Ford Focus ZX3
2004 Ford Focus ZX3
Drive more, worry less.
Old 06-26-2007, 06:15 PM
dunno513's Avatar
dunno513
Alton, NH, USA
Car: 06 TDI NB w/DSG
One suggestion is to lift where the engine meets the tranny for lifting the front up at one point.
Says to use a block of wood to protect the metal surfaces.
Personally I like to lift vehicles at a strong point on the suspension. Heck, it already has the weight of the vehicle on it so it must be strong enought to lift it a few inches.
This way you don't have to lift a vehicle any higher than you need to since the wheel won't drop. Just my $.02
Tags
jack
iPOD jack bonnie Questions, Issues, Concerns, or Problems with the New Beetle 6 04-14-2007 02:55 AM
anyone here own a cracker jack baseball beetle ? Bugman Miscellaneous Hoo-Ha Archive 53 12-04-2006 01:12 AM
New Custom Beetle Jack + Jackstands dvious Miscellaneous Hoo-Ha Archive 6 09-26-2006 07:14 PM
FS: Polyurethane Jack Pad for your floor jack turbomonkey@ Market Place Archives 95 09-19-2006 07:37 PM
Hydraulic jack FineExampl 2.0 Liter Gas 5 11-09-2005 02:10 PM
