Gauges: Decisions, Decisions, Decisions - NewBeetle.org Forums
View Poll Results: Which gauge is more important?
Oil Pressure 9 75.00%
Oil Temp 3 25.00%
Voters: 12. You may not vote on this poll
Old 08-28-2007, 06:42 PM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
Default Gauges: Decisions, Decisions, Decisions
Ok, I'm still on the gauge subject, but I'm beginning to get a much better handle on things.
I ordered the Autometer 3-gauge pod for the dash of my NB (should be here this week) and need to get some gauges.
I'm "concrete" on getting Boost & EGT (these are decided), and I can't decide what's better Oil Pressure or Oil Temp .
The way I look at it is if I loose oil pressure, because of how the diesel handles oil in a rupture situation, I'm going to loose the oil so quickly I may not be able to react in time to really 'minimize' potential damage. So, what's this gauge really worth, asthetics?
If I get oil temp, I can monitor it like I monitor the boost/EGT, by looking at it regularly while driving. If the temp is starting to creep out of operating limits, I can shut things down before major damage occurs.
So....I'm thinking of oil temp over oil pressure. Opinions/advice most welcome.
Second, I'm contemplating adding a pillar two-gauge pod down the road. When I do this I'll add the other oil gauge and possibly a water temp.
Third, I'm still up in arms about mechanical vs. electronic boost gauges. I've read several posts about electronic, but I'm iffy about the electronic - the 'direct' vaccume connaction with mechanical makes me think it's more accurate. Posters say that electronic give equal or greater performance, and have full sweep whereas mechanical do not. I'm not really sure what "full sweep" means or how it applies to the gauge itself, but I'm thinking it may be better ?
Just for info...I'm debating on the Stewart Warner gauges vs. the Autometer Cobalt series. Both have good reputations, both have awesome looks (the cobalt matches NB's color theme exactly, and the SW's LEDs can be changed to blue for a 'matching look'. The SW are also drastically cheaper. SW Boost and Oil-whatever: $42ea, AM Boost: $168. Right now I'd feel comfortable getting SW Boost & Oil (adding the other 1 (EGT) gauge when it's affordable (it's $150)), OR, AM Boost (adding the other 2 gauges when it's affordable (Oil: $60-120 [pressure vs. temp], EGT $120)).
All advice and opinions would be greatly appreciated .
'98 NB, Black TDI running on SoyPower!
Nonnny, nonny, my TDI is faster than your gasser, gets better mileage than your gasser, and will outlast your gasser...sucks to be you, huh?
Mods: Rocketchip Stage 3 Euro, PP520s, DG Racepipe/EGR delete, Neuspeed intake, G60/VR6 clutch, Audi TT bushings, Shine Racing suspension w/ bilstein shocks/struts, triple gauge pod: boost, EGT, H2O temperature, ventectomy, mufflerectomy, catectomy, CCV mod (environmental version), & one he|| of a driver.
Old 08-28-2007, 07:11 PM
noR's Avatar
Administrator
Jackson, MS, USA
If you get a hole in the oilpan and dump fluid; what'd happen to your EGT's?
& I'd go mechanical. It just seems like a simpler machine. Fewer points of failure.
noR | me | Phrog
PHROG
Old 08-28-2007, 07:27 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
Oil pressure. There's no way in hell your oil temps will get ever so hot that u'll hafta stop the car. Oil temps is really for highly modified cars on the track, but many times they have an oil cooler.
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 08-28-2007, 07:41 PM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
Right-o, I'm modified, but not what I (or probably anyone else) would consider "highly modified". To boot, I'm planning on doing a larger oil cooler from a V6 4motion Passat (see this post on TDIClub).
Old 08-28-2007, 07:49 PM
AccountingTroll's Avatar
Beer BEer BEER beER
PA, USA
Car: 06 NB TDI option 1
Ohhhh, I like those gauges. To bad I'm at work and eBay is blocked. (Wonder why?)
Oh, the three gauges I'm getting for my ride are Oil Pressure, Water Temp, and Boost.
FYI, a dezzel does not make vacuum. That's why they have a vacuum pump. (this is from the other thread that I can not read anymore)
I am a Man,
But I can change,
If I have to,
I guess.
Old 08-28-2007, 10:53 PM
FarrisK's Avatar
Semi-Lurk Mode: GOOOOO
West Richland, WA, USA
Car: 2004 Ford Focus ZX3
Another option to throw in the mix is to run a Water Temp gauge instead of an Oil pressure gauge. Personally, it really bothers me that our cars don't have water temperature gauges... just a little blue light.
2004 Ford Focus ZX3
Drive more, worry less.
Old 08-28-2007, 11:01 PM
turbos03's Avatar
TX, USA
Car: 2003 Reflex Silver Turbo S... Sold
"The way I look at it is if I loose oil pressure, because of how the diesel handles oil in a rupture situation, I'm going to loose the oil so quickly I may not be able to react in time to really 'minimize' potential damage. So, what's this gauge really worth, asthetics"?
oil temp should be watched in a turbo/supercharged car, plus you're in a hot area so expect to see higher oil temps (I did when I was running one, I'm in TX)...
oil pressure gauge can come later if you do end up running another gauge pod, but you're right on the money if you're in a rupture situation you're going to lose pressure so fast that you aren't going to be able to react in time to save the engine...
mechanical vs. electronic... it's up to you, but like I said before for the money the mechanical type are a good choice...
turbo lag n. The period of time between owning a 2.0 VW and trading up to a 1.8T...
Old 08-29-2007, 05:08 AM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
I looked at Glow Shift on eBay and you can buy a package of 3 gauges Boost, EGT, and Oil Pressure for $139.99 + $19.99 for shipping. That's $159.98 for all three to your door! Man, that's awesome!
Now, if I can only get Checker Auto Parts to match the price and give me their guaranteed 5% lower pricing . I'd walk out for 132.99 + tax. That's PIMP!
Old 08-29-2007, 08:15 AM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
Originally Posted by Evanrude
Not many places at all will match eBay prices or internet prices...
I totally understand, I was shocked when the counter clerk @ Checker said that they'd match an internet price!
Old 08-29-2007, 03:32 PM
Billsbug's Avatar
USA
Water temps is BY FAR the priority, next is oil pressure, then boost. You overheat, ur toast, u have no oil, ur toast, u have no boost, ur just slow.
Old 08-29-2007, 04:05 PM
Beer BEer BEER beER
PA, USA
I agree with this to a point. With his set up he needs to know over boost and high EGT. If it were my car, I'd be putting in 4 with EGT on the A pillar and water, oil pressure and boost on the 3 center pod.
Old 08-29-2007, 04:45 PM
Billsbug's Avatar
USA
I agree w/that set-up, but are you going to be racing this TDI? Why would u need an EGT gauge for everyday driving?
Old 08-29-2007, 05:15 PM
Beer BEer BEER beER
PA, USA
(with a big smile on my face) Why did he put a Stage 3 Euro Rocketchip in?
I have to assume he's going to use that chip. I know I would.
Old 08-29-2007, 05:41 PM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
Man, you guys always get me in trouble my making me realize I need to buy more stuff ! I agree about the water temp, it is a very important gauge - especially here in AZ where most of our summer is over 110 degrees and spikes to 120 degrees are not that out of the ordinary (BTW - it doesn't matter how how it is after 110, you just run from A/C'd house, to A/C'd car, to A/C'd work, to A/C'd shopping, and don't go outside for any length of time ).
Anyway, with all this new info I'm solid on the boost gauge and still up in the air about the other two. The question THEN becomes what are the best choice of gauges for the last two holes: oil pressure (oil temp. is out for now), EGT, and water temperature?
I'm thinking: boost, EGT, and water temperature , but not exactly sure.
Old 08-29-2007, 06:08 PM
Billsbug's Avatar
USA
There's a such thing?! HP/TQ? (may want to swap in a TDI later)
Old 08-29-2007, 08:06 PM
Beer BEer BEER beER
PA, USA
Ohhhhyaaa. You can push that engine even futher. With just the RC3 that car should easly push 185hp. I'm not sure what the torque curve looks like.
Now add on bigger injectors, turbo...
How much money you got?
Old 08-29-2007, 08:14 PM
Billsbug's Avatar
USA
Stage 3 is only 185hp?
Old 09-06-2007, 04:01 PM
Midland, TX, USA
Car: 10 VW NB GLS TDI
Water temp & oil pressure are VERY important...when you start pushing the motor hard I'd get an EGT. The only time the EGT gauge is gonna do you any good is when your excessively pushing the car out of the turbos efficiency range, hot lapping the car or you have a real aggressive tune. When it comes to diesels I tend to think boost is the least important because you can usually tell if you have a leak by the sudden loss of power (as with any turbo'd car) or alot of smoke. Its useful information but its not a gauge thats gonna keep your car alive. If it was a gasoline car then I would definitely recommend getting a boost gauge.
I don't know too much about the RCx stuff as I just joined the TDI world so if RC3 pushes your car pretty hard then I'd consider getting an EGT as well.
If you want to do things RIGHT and keep your car healthy I'd just bite the bullet and get all 4. You could put the 4th one (boost) in the glove box if you had to.
Old 09-06-2007, 05:17 PM
bigsexyTDI's Avatar
Diesel Freak
Paducah, KY, USA
Car: '98 TDI
It aint about the HP in a diesel brotha...its the torque. And actually 185 is pretty darn optimistic. But like I said...nomadduh!
Check out this dyno chart. Its a guy on TDI club.
about 150 HP but almost 350 FTLBS!!! haha and at 2300RPMs
Thats the difference in the TDI.
SMAUG - '98 UNI-RED NB TDI, UPSOLUTE, SPRINT 205's, EIBACHS, BILSTEIN HDs, CAT & MUFFLERECTOMY, .:R32 ARISTOS, GENERAL EXCLAIM UHPS, 250K AND CLIMBING
Old 09-06-2007, 05:22 PM
Midland, TX, USA
Why did the torque & hp spike and drop so much?
Gauges mikeeyd Styling Modifications 3 12-24-2006 11:00 AM
Gauges number9 Questions, Issues, Concerns, or Problems with the New Beetle 3 09-01-2006 03:25 PM
Gauges tdi.phantom Technical Modifications 0 06-30-2006 05:33 AM
Gauges tenach 1.8 Liter Turbo 13 05-16-2006 03:01 PM
Gauges Help: What does this mean... GGKauten 1.8 Liter Turbo 1 05-03-2006 06:43 AM
