Sticky Shifter/ - NewBeetle.org Forums
Old 08-29-2007, 03:53 AM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
Default Sticky Shifter/
I was pulling into my driveway this evening and the car seemed to stick in 2nd gear (it's a 5spd). It was really hard (almost impossible) to shift into 1st gear . I pulled back out of the driveway and drove around the block. The shifter seemed 'sticky' or 'hard to shift' between 1st, 2nd, and 3rd; 4th and 5th seemed to be ok.
After driving around the block and up and down the street a few times things seemed to loosen back up but it seemed that I still have to exert more force than I used to when shifting into 2nd gear (and 2nd gear only).
As I bought the car used at 90K (it now has 116K), I'm not sure if the gearbox oil has ever been changed (this is on my list of things to do, but I want to change the 5th gear to something that will give better mileage when I do it).
Any suggestions?
I'm going to go out again this evening for an extended 'test drive' to see if things change or (hopefully) return to normal.
'98 NB, Black TDI running on SoyPower!
Nonnny, nonny, my TDI is faster than your gasser, gets better mileage than your gasser, and will outlast your gasser...sucks to be you, huh?
Mods: Rocketchip Stage 3 Euro, PP520s, DG Racepipe/EGR delete, Neuspeed intake, G60/VR6 clutch, Audi TT bushings, Shine Racing suspension w/ bilstein shocks/struts, triple gauge pod: boost, EGT, H2O temperature, ventectomy, mufflerectomy, catectomy, CCV mod (environmental version), & one he|| of a driver.
Old 08-29-2007, 04:08 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
Please lemme know about the 5th gear change, rpm difference and the cost if you would...
Old 08-29-2007, 07:17 AM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
I just got back from driving around an empty parking lot and the shifter seemed to loosen back up. I'm 95% sure that its back to where it was before the incident .
Anyone know why it would have done this? Is it possible for the linkage to bind up?
Old 09-01-2007, 04:04 AM
dblvsn's Avatar
Resident BADA$$
Tempe, AZ,
Car: '98 TDI
I've put about 200mi on the car/shifter incident and all seems to have worked itself out - hurray!
Old 09-02-2007, 12:48 AM
Beetlemania's Avatar
crank it up, suckers!
Broken Arrow, OK, USA
Car: 1999 Silver Aero GL
I hope it stays that way. I've had that issue for a few years, and it's getting progressively worse over time, though it seems to go away some days. I often have trouble getting into reverse, too.
I've heard there's a way to adjust the linkage, I just haven't heard what the method is.
Anyone? Anyone? Bueller?
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings!
Mi Bacca es Chewbacca!
I'm one of those people. Whatever that means.
im thinking u should sticky me ^_^ v-dubed 1.8 Liter Turbo 11 08-26-2006 11:58 AM
Sticky Topics? awetsock Suggestion Box 2 06-25-2006 04:05 PM
Sticky Problem angelworks 2.0 Liter Gas 2 01-28-2006 04:48 PM
Sticky window Shellij Questions, Issues, Concerns, or Problems with the New Beetle 1 10-02-2005 02:13 PM
