Turn signal - NewBeetle.org Forums
Old 08-27-2008, 09:42 AM
4toyhln's Avatar
Silver Bullet
Mattawan, MI, USA
Car: 2002 new beetle Gls TDI
Default Turn signal
Hello all, have a new problem with the nb. My cruise quit working a little while ago. Looking for answers on what u all might think may be the culprit. When the cruise did work, i would set it and be cuising along and when I went to change lanes using the right turn signal it would cut out. It also would cut out when turning off the high beams. I believe the problem lies in the unit attached to the end of the turn signal arm. Any suggestions?
2002 NEW BEETLE GLS TDI (111,000 MILES)
2004 CHEVY SILVERADO 2500HD DURAMAX (114,000 MILES)
2004 YAMAHA KODIAC 450 4X4
2006 30' STARCRAFT TT
Old 09-09-2008, 05:55 PM
Albuquerque, NM, USA
Car: 2003 GL TDI
Either your turn signal switch is worn out or it's disconnected.
Kent Christensen
Albuquerque
'03 GL TDI, '07 GL320CDI, '06 E320CDI
Old 10-04-2008, 04:53 PM
No Slug's Avatar
NE,
Car: 2001 Dark Blue APH 5-speed
I've got the same issue. How is it resolved? Is it in the relay or the turn signal stalk?
'01 Batik Blue 1.8T APH 5-speed 235,000 (s)miles!
turn signal flasher beetlejuice Questions, Issues, Concerns, or Problems with the New Beetle 10 04-27-2008 12:07 AM
Turn Signal Lights Kenya_7 Parts and Accessories 7 11-07-2007 02:39 AM
Turn Signal Popped Out! Ted 2.5 Liter Gas 3 09-04-2006 04:57 PM
Need a turn signal lever XxchavoxX Market Place Archives 1 06-07-2006 07:13 PM
Turn Signal Issues 73ladybug Questions, Issues, Concerns, or Problems with the New Beetle 2 05-03-2006 02:16 PM
