how to replace front turn signal bulb in 2006 tdi nb - NewBeetle.org Forums
Old 10-06-2008, 01:27 AM
Question how to replace front turn signal bulb in 2006 tdi nb
can anyone help me replace the front bulb for my turn signal? (advice or pics) I can't figure out how to get to it? Help??? It is a 2006 nb tdi.
Thanks.:
Old 10-24-2008, 07:05 PM
Cool
Not as hard as you would think. I just did mine. When you open the hood look, on the driver's side, just in front of the battery box and you'll see a 3/16" allen stud. You may need a flashlight. Printed on the headlight housing you'll see a lock/unlock picture with a directional arrow. Get a nut driver and turn the allen stud a half turn in the "unlock" direction. It's clearly marked. Once you do this, take your hand and gently tap the outside of the headlight assembly. It will loosen up. Pull the headlight assembly out about an inch and it will stop. Now, get a paint stick or something like it. Look between the battery box and the air filter. You'll see a silver level. Push down and hold the silver lever. It doesn't take much pressure at all. Once you are holding this down, pull out teh headlight assembly. You may want an extra pair of hands to do this.
You will need to remove the air filter cover and the battery cover. This is fairly straigh forward. Just be patient and don't break any of the little parts.
Good luck!
2006 NB Front Turn Signal bulb replacement HighCompression Technical Modifications 3 10-12-2011 12:07 PM
How To replace Turn Signal Bulb in '06- marvins_dad Technical How-To 0 07-05-2008 01:06 PM
2006 on: Front turn signal bulb replacement how-to with pics HighCompression New Member Forum 0 05-08-2008 11:59 PM
Front turn signal bulb help..please beastle Technical Modifications 1 04-06-2008 06:50 AM
New member - HIDs worth it? Turn signal bulb replacement Krzys New Member Forum 6 02-02-2007 05:08 PM
