mine just rolled 123K so here's what I've done so far.
Timing belt and water pump (obvious) If they don't have records and can't produce them, assume it hasn't been done and get it done! front wheel bearings (depends on the car, may or may not be an issue) Cleaned turbo and intake (again depends on the car) brakes rotors nothing else really. Maybe someone else will chime in and see what else you need done.
Just because it's done at a Dealer, doesn't mean it's done Right!!! "Probie" 2k12 ToD Checklist Dub Gestapo |
A 2004 TDI is going to have all the same body and electrical issues/concerns as any other NB/A4 car of this vintage. The 2004 TDI engine is prone to a few more issues, which I will touch on below. If I was in the market right now, I would personally be looking at the 2003 or older TDI's, as they do not have some of the issues that the 2004+ models have with valvetrain wear.
5 speed or DSG? If 5 speed, beware of DMF failure issues...they seem to crop up around that age/mileage. A fairly easy fix in this case, just replace it with a SMF clutch setup. DSG...also beware of DMF issues, only difference is you are still stuck with replacing it with a DMF. DSG transmissions require fluid/filter changes every 40k, no exceptions. 2004+ models also have the infamous cam/lifter wear issues. The valve cover should be removed and the cam/lifters should be inspected for abnormal wear. Replacement cost is about $2000 or so. Glow plugs. VW has a recall on these now I believe. VW fitted these engines with ceramic glow plugs. After awhile, these tend to break off and cause engine damage. They are now being replaced with steel glow plugs, the ECU must also be flashed to correct the voltages. Timing belt will have to be done if there is no history on it. Better safe than sorry. Interval for these is 100k miles. If this was has not been done it is on borrowed time. All components in the path of the belt must be replaced; water pump, tensioner, idler roller in addition to the stretch bolts a such. Here is an excellent example of a quality kit: http://www.dieselgeek.com/servlet/Detail?no=368 Now for the good news. You are in a good area for TDI mechanics. Take a look here: Trusted TDI Mechanics - Google Maps In particular...these guys are excellent: MOGolf http://forums.tdiclub.com/member.php?u=5699 Glenn will likely be your best bet when it comes to 2004+ engines. Jon's Auto - Jon Hamilton - RallyTDI jonwilliamhamilton ASE-Certified Mechanic 22291 State Route 4 Marysville, OH 43040 937-209-0187 http://forums.tdiclub.com/member.php?u=65315 Jon's Auto - Specializing in VW and Audi Repair - Marysville, Ohio Growler (also a member here by the same name) Aaron Bruckelmeyer Growlers TDI service 4428 Drifton Dr Columbus, OH 43227 growlertdi@gmail.com or PM is best http://forums.tdiclub.com/member.php?u=17936 Get in contact with and network with these gentlemen and others in your area. They are a great resource to have and they might be able to give you a hand with pre-purchase inspection to ensure you get the right car for the right price. They can also take care of you for all your service needs for a very fair price and you will be able to sleep well at night knowing the job was done right. VW stealers should be avoided at all costs and never be allowed to even touch your vehicle. Good luck and happy hunting. ![]()
2000 New Beetle GLS TDI 5 speed swap w/SBC Stg 3 clutch and Dieselgeek short shifter, RC3, PP520's, Eurojet SMIC, 3 bar map, Dieselgeek skidplate, 2" lift w/VR6 springs, 2.5" turbo-back straight pipe "weedburner" side exhaust, air horn, ABD Cup front bumper, HID retrofit, LED tails, Bernt Pod w/McNally gauges. WISH LIST: VNT 17/22 hybrid turbo, RC5 and other silly stuff. Last edited by DZLBUG; 09-21-2009 at 08:35 PM.. |
FYI DZLBug, I do have experience with timing belts on the PDs. the glow plug change I can physically do, but the dealership is the best option for the reflash, unless you are interested in a chiptune and can be in Marysville, on November 14th at Jon Hamiltons place...
| WTB - Lady Bug Items | Wendie | Parts and Accessories | 4 | 09-28-2008 04:49 AM |
| NBC Items for Sale! | belle | Market Place Archives | 0 | 11-27-2006 06:42 AM |
| Does anyone want to buy my items? | crazi_daisy | Miscellaneous Hoo-Ha Archive | 0 | 04-08-2006 09:42 PM |
