Fuse 34 10amp, Engine Control Elements keeps blowing on our 2000 TDI 1.9 manual tranny. It causes the turbo not to work. Anyone have any idea what we need to check so we can fix it? Thanks in advance for any help.
Well, obviously it is a wiring problem. When you say it makes the turbo stop working, what are the symptoms? Are there any codes at all?
There are three electrical components I can think of that are integral to turbo operation: MAF sensor MAP/IAT sensor N75 valve I think the only way to go about diagnosing this, you're just going to have to get in there and check those sensors and the wiring. This is not a common problem at all, I've never heard of it before and I searched TDIclub with no luck. Where are you located? There is a list over on TDIclub of "Trusted Mechanics" who know TDI's...check it as there may be someone nearby who can help you out. Good luck.
| Comfort sys comp fuse blows when rear defroster turned on | albin49 | Questions, Issues, Concerns, or Problems with the New Beetle | 6 | 03-14-2012 06:04 PM |
| Cooling fan, fan control module, default fuse block and burnt wires | jhwkr | 2.0 Liter Gas | 4 | 05-26-2008 03:39 PM |
| wtb fan control unit and fuse box | GLUVBUG | Parts and Accessories | 0 | 05-19-2008 06:35 PM |
| Fuse Help! | justjames | New Member Forum | 6 | 02-19-2007 02:25 AM |
| Comfort sys fuse blows when rear defog turned on | albin49 | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 12-12-2005 03:28 AM |
