tranny fluid type - NewBeetle.org Forums
Old 11-02-2009, 08:39 PM
MATDIBug's Avatar
My NB wants 2 b a Turbo S
Methuen, MA, USA
Car: 1999 TDI GLS
Default tranny fluid type
What is the best fluid for the manual tranny in a 99 NB TDI?
I appreciate the help.
1999 NB TDI, 191k and still going strong
Old 11-02-2009, 09:36 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
OEM VW is generally considered to be the best. G052 is what was specified originally, but has now been superceded by G060 and G070. Any of these will work, but I have heard good things about the new G070 as it seems to be a bit thinner (good for cold climates) but still a VW fluid.
Redline MTL or MT90 also work well, the MTL variety especially for those of us in the Great White North as it is not as "thick" when it gets cold. Some run straight MTL and others run a mix of that and MT90.
The most important thing is to get a GL4 spec 75w-90. Not GL5 or GL4/GL5. The GL5 additives tend to work fine for awhile, 20k miles or so, but then they begin to mess up the brass synchronizers in the transmission.
It will take slightly less than 2 liters to fill the transmission. Remember to remove the check/fill plug BEFORE the drain plug. That way, if you run into any trouble removing the check/fill plug...you'll at least still have lube in your transmission.
2000 New Beetle GLS TDI
Old 11-03-2009, 10:52 AM
MATDIBug's Avatar
Methuen, MA, USA
Car: 1999 TDI GLS
DZLBUG, I appreciate your help. Right after I posted i saw all the links at the bottom referring me to different threads and I did a lot of research. Luckily for me because I had some Royal Purple Synthetic gear oil but as you mentioned before it is GL-4/5 not just 4.
I will take your advice and go with the MTl/90 mix, I have seen that in a few threads and even on TDIClub. Seems to be a good mix for colder areas as I have heard the MTL alone may be too thin.
Again, thanks!
Old 11-03-2009, 01:40 PM
Growler's Avatar
strange things are afoot
Columbus,, OH, USA
fyi, I have that mix in my golf..
MTL/MT90 and I am going to swap it out for oem G070..
I have felt and driven both and the G070 wins hands down.
~Aaron~
Old 11-03-2009, 02:49 PM
We have a few different options available (including complete service kits), but the RedLine MTL and OEM fluids are the best sellers:
Volkswagen New Beetle TDI > Maintenance > Transmission
oil, tranny,brake fluid.... what to use Daisey 2.0 Liter Gas 6 06-16-2009 04:19 PM
Tranny Fluid ? DOUGDANGER Transmission Talk 1 09-20-2008 11:56 PM
brake fluid type bobbittle Technical Modifications 0 11-02-2006 09:04 PM
What type of power steering fluid? jc918t 1.8 Liter Turbo 7 10-28-2006 02:09 AM
What type of fluid can i use for the power steering? mezonesxbox Questions, Issues, Concerns, or Problems with the New Beetle 5 06-15-2006 09:23 PM
