The special tools you will need are:
Harbor Freight - Brake Caliper reset tool it twists the piston as it pushes it in. It's only needed for the rear pistons since they screw into the caliper, but it works for the front ones too. this is the exact set i have, and i've used it on the beetle, mk4, and my audi. to get the front (and maybe rear i don't remember) caliper nuts off, you'll need: Harbor Freight - Metric Hex Sockets I mean, if you have metric allen wrenches, if you can get a good grip on it, it should work, but those on a ratchet are sooo much easier. The rotors are held in with a set screw, it's sometimes a pain to get the screw out and it strips easily. Just use a big philips head and you should be fine. It's not a big job, or at least it's as big as doing brakes on any other car.
The mind boggles at folks that would attempt this without reference to VW procedures, i.e. the Bentley manual.
Kent Christensen Albuquerque '03 GL TDI, '07 GL320CDI, '06 E320CDI |
Put anti-sieze on the hub before installing a new rotor. You'll also need caliper pin lube for the glide pins. My preference is a product called SilGlide. It's also worthwhile to get a brass bristled wire brush to clean up the caliper riding surfaces before you install the new pads. I clean everything with brake parts cleaner and I also use permatex red disk brake quiet on the back of the pads. I use a large C Clamp to compress the front pistons. Many people will loosen the bleed screw and expel the old fluid when compressing the piston, I do not typically do that. |
you should then post the procedure from the bentley manual. if your mind boggles that much, other wise your 2 cents are worthless.
Here is a front brake how to with nice pics for mk4 tdi (same as nb): Front Brake Job 'How To' - TDIClub Forums Here is rear brake how to: Rear brake pad and rotor replacement - TDIClub Forums There is lots of "how to's" here HOW TO's - TDIClub Forums Good luck and watch out for that pesky screw rackaracka talks about. It can be a PITA. |
This is very helpful thanks for the info!
![]() Quote:
| Rear Brake Caliper Piston and E-Brake Cable Won't Budge | themerk | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 12-13-2010 09:25 PM |
| WTB: Third brake light/Center High Mounted Brake Light | petah | Parts and Accessories | 1 | 04-28-2009 02:52 AM |
| WTB: E-brake | Smooth | Parts and Accessories | 1 | 01-31-2009 04:15 PM |
| Difference between 2002 Sport and 2002 GLX | Stinkbug | Technical Modifications | 5 | 07-19-2006 06:06 PM |
| Brake Light Recall on 98-2002 NBS but... | Moviequill | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 07-14-2006 04:36 PM |
